Discussing Oil Question in the 96-98 Forum. Im getting ready to put Heads and cam on my car to finish up the ...
Old June 20th, 2007, 08:25 PM   #1
68 dlxcoupe's Avatar
2004 Mach 1
13.30 @ 104.47
Oil Question
Im getting ready to put Heads and cam on my car to finish up the PI swap and sence I got front cover off I'm replacing my timing chains, tensioners, and I want to put in a high volume oil pump. Is it possible to put an oil pump and pickup tube in with the engine in the car. Its a 97 GT btw. Thanks and what oil pumps do you reccomend. Willl a High Flow FRPP pump do the job? Thanks
http://www.moonshine-media.net/68dlx2.jpg
EAGLE SCOUTS OR GTFO
MyStangOpens (12:01:05 AM): honey nut for me
Old June 21st, 2007, 03:49 PM   #2
It is not suggested to run a high volume pump on a iron block. I have read over the year that a few guys have had issues with the pump sucking the pan dry. The Cobra pump was designed for the aluminum block,with expanding rate of aluminum they needed a pump to push more oil through the narrowed oil passages.
IMO the factory pump is more than enough without a larger pan or more oil capacity.
Old June 21st, 2007, 06:45 PM   #3
2004 Mach 1
13.30 @ 104.47
so I dont need a high volume oil pump with an iron block. Ok now can I install one with the motor in the car? Thanks
Old June 21st, 2007, 06:51 PM   #4
I'm not sure, the hard part would be to remove and install the pick up bolts.
Threads Similar to: Oil Question
88' GT Speedo' Question. Plus Another Gauge Question. Mr_Evil 5.0 Mustangs 8 March 16th, 2008 01:31 PM
Muffler question (visual aspect) + Emblem question warrior86 Visual 6 November 20th, 2007 09:55 PM
