Discussing how much boost??? in the 96-98 Forum. ok guys just wondering how much boost can some superchargers go to??ive decided to ...
Old June 22nd, 2007, 03:51 PM   #1
how much boost???
ok guys just wondering how much boost can some superchargers go to??ive decided to get an extra 4.6 engine from a guy at work and forge it and everything....what cams,heads should i get??and what compression to set up at??i want to hit at least 600 horses with the motor and intercooled supercharger..but i dont know which supercharger to get and what boost it will go to....what cams heads and supercharger yal think i hsould go with??and compression???
Old June 22nd, 2007, 04:24 PM   #2
nes
vortech t trim is good to like 26psi i think, the procharger d1 is good to like 32psi. look into either one of those.prolly be able to do it with p&p pi heads and hp292 blower cams of course thats with high boost (prolly around 18psi)... thts just how i would approach it, with a forged bottom end, and 9:1 compression
laser red 98 gt- stock
Originally Posted by supermachone View Post
psh dude i slit throats all the time
Old June 22nd, 2007, 05:18 PM   #3
You can go with anywhere from a Vortech S-trim, or YS-trim. Procharger P1SC, Paxton Novi. You can run as much as you want. Your block will hold it. But I would say if you want to keep it reliable, dont go over 14lbs. YOur Really running the risk of tearing your rings up after that.. Yeah, you can run 17-20lbs, but you really have to take into consideration your driving habbits, whats the car being used for? Blah blah. You also need to know, that if you want to make sure your motor is good, your going to really want to tear it down around 45-50,000 miles, freshin the rings and barings. Its just a good idea. You can run 9:1 compression, this will also make you run less boost. Then again, you can just run a 331 that breathes well with 14lbs and that will get you right were you want to be...:-P
Fast, Cheap or Reliable. You get to pick TWO!
Old June 23rd, 2007, 12:17 AM   #4
ok so what cams from where should i get and are yal saying just port and polish my heads..will they be able to handle the boost???its my daily driver so i guess i will only set it at 9 or 10 pounds for daily...and on superchargers how do you turn up the boost??do you have to buy pulleys or something???
Old June 23rd, 2007, 02:18 PM   #5
The Cable Guy...
ChrisJ's Avatar
SLOW
I love my t-trim...So that is an option for you...
I would also like to recommend the Paxton Novi 2000...
I would also like to recommend the Procharger D1SC...
Heads/Cams
VT Engines makes great heads and cams for the mod engines...
Modular Powerhouse makes great heads and cams for the mod engines...
Me personally I would have my compression ratio around 8.5 to make it boost friendly...
My Junk
www.myspace.com/cjobe
Threads Similar to: how much boost???
1 psi boost gooberhead320 V6 Mustangs 21 February 13th, 2008 09:25 AM
How much boost? Cor9er 94-95 8 July 26th, 2007 02:22 AM
boost??? 2001bullitt 99-04 3 April 26th, 2007 03:41 PM
Turbo Boost vs Super Boost droppedbass87 Poweradders 12 October 16th, 2006 09:56 AM
How much boost should i be seeing? Stangtuner Poweradders 2 December 21st, 2005 08:58 PM
