High Compression and FI
Old June 24th, 2007, 01:53 AM   #1
blk98gt is on a distinguished road
Im new at all this stuff and I have seen people say that the PI heads are bad for any FI becuase the heads raise the compression. Why is a Higher Compression bad for FI?
Old June 24th, 2007, 02:54 AM   #2
DrHolliday is on a distinguished road
FI raises the compression on an engine by cramming more air into it. If your compression is already high then you can't run as much boost without upping the octane in your fuel.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old June 26th, 2007, 05:54 PM   #3
Proud American
MustangMatt96GT's Avatar
Also with less compression and high octane fuel you can pull more timing and create more power! The 99-04 motors have a 9.6:1 CR and our NPI 96-98 motors have a 9.3:1 CR. When the PI (99-04) heads are put on our NPI motors the compression bumps up to 10.6:1. The reason being is the different size combustion chambers and different dished pistons. PI motors have a 17 cc dished piston with a 42cc combustion chamber where as the NPI motors have a 11cc dished piston and 51cc combustion chambers. So if you put PI heads (42cc chamber) with NPI pistons (11cc dish) it creates the higher CR. Now if you run low boost with your PI heads with NPI motor it wont cause a problem but you would be better off to take your NPI heads and get them Ported and polished and keep the low compression ratio to make more power safely!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old June 26th, 2007, 06:21 PM   #4
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
Removing some of the combustion chamber will help lower the compression ratio, you'll end up with around 46-48 cc chamber. If you take to much out you will end up hurting the performance you are trying to gain. Average combustion chamber on a P.I heads is actually 44cc's they rate them at 42 as the smallest of the average, I have actually seen some measure out at 46 untouched. If you have your heads ported by a real head porter all this information should be sent to you with the heads.
Back to the topic, you can run higher compression but you will need a higher octane fuel to support it. One way around this is to adjust the timing trim around to support the added compression. Built modulars running forced induction love compression, unless you plan on digging into the lower end I would look into other options.......
Old June 26th, 2007, 06:26 PM   #5
Proud American
You will also be digging into your wallet alot with the high octane gas! lol but then again Horsepower sure aint cheap!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old June 26th, 2007, 09:12 PM   #6
Why'd you have o bring up that evil 3 letter word? Ever since the KB my best tank has been about 13 mpg, lmao
Mustangless atm
Old July 3rd, 2007, 11:27 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: High Compression and FI
Its not. Some one fed you some crap.
Threads Similar to: High Compression and FI
is 10.5:1 compression too high for a supercharger? 94' Cobra 351 General Tech 33 May 5th, 2008 09:05 PM
High vs. Low Compression 87StangLX General Tech 14 November 17th, 2007 11:42 PM
A Question About Prochager With High Compression blue03mach1 99-04 15 November 9th, 2007 03:46 PM
compression greenstallion General Tech 2 March 6th, 2007 12:24 PM
compression too high for a supercharger? 94' Cobra 351 Drag 3 January 11th, 2007 12:05 AM
