98 gt bogging on wot - Forums at Modded Mustangs
post #1 of 25 Old June 17th, 2012, 12:29 AM Thread Starter
Sammy8172's Avatar
Hey everyone new to the forum here. I just recently picked up a 98 gt from a cousin of mine who had it garaged since 06. The car will pull HARD while its running cold but after I give it a few minutes to warm up and give it wot it just doesn't move. It'll move up rpms but there's just no acceleration what so ever. I'll probably post videos tomorrow when I have time but I'm pretty sure it's not a fuel issue at this point. I can gradually give it gas and it'll redline every gear. I've changed the fuel pump, fuel filter, spark plugs/wires, and maf. At first it was running the stock h-pipe but I thought that maybe my cats could be clogged so I replaced my midpipe with an o/r h pipe but that wasn't the issue either. And usually even after it warms up it'll go but after about 2500 it'll just bog out right away on wot.
It's pretty much stock, besides the bbk cai and sr peformance underdrive pulleys. no computer tune or anything. I didn't get a check engine light until I had the o/r pipe installed. I ran some intake cleaner through one of my vacuum hoses going to intake and blew out a ton of white smoke through exhaust. This was before I put on the h pipe. After that it threw CEL p0172 and p0174 one side running rich and other running lean..I reset the computer and no code since. The mufflers after midpipe have a few holes in them, I just got some new ones in the mail today just need to get them welded soon. I'm pretty positive that wouldn't cause it to bog out the way it does though.. Could my fuel injectors be clogged possibly? Will it pull like that while its cold and just give out when it gets warmer? Or could I just be having an issue with an upstream o2 sensor or any other sensor dealing with my intake or tps? I had no CEL what so ever and I was still having this issue so it's got me pretty stumped. Any help would be appreciated, thanks in advance
wot after I let the engine warm up-
neutral, me giving it wot then just gradually giving it gas all the way-
Sammy8172 is offline
post #2 of 25 Old June 17th, 2012, 12:37 AM
Watch n learn
Ponyryd's Avatar
Fuel issue would be my guess, how much fuel was it stored withÉ anything less than full I`d say you need a new tank, pump and filter.
Ponyryd is offline
post #3 of 25 Old June 17th, 2012, 12:39 AM Thread Starter
Sammy8172's Avatar
Forgot to mention I picked up a new tank from the junk yard. He said he left the car with no fuel but I replaced it anyways the old tank was a little corroded.
post #4 of 25 Old June 17th, 2012, 01:36 AM
Watch n learn
Ponyryd's Avatar
My guess would be pump, it would have seen all the moisture over the years of having an empty tank. Check your fuel pressure, I bet the pump dies when warm.
Ponyryd is offline
post #5 of 25 Old June 17th, 2012, 05:37 AM
Is it an auto or manual? From the way you are describing it, it sounds like the transmission is slipping once it warms up. If it were bogging, then RPMS wouldn't be climbing, or they would be climbing slowly.
If it's truly bogging, then my money is going to be on an O2 sensor or the MAF.
1997 Cobra.
JC316 is offline
post #6 of 25 Old June 17th, 2012, 11:27 AM Thread Starter
Sammy8172's Avatar
It's manual. And definitely not the transmission cause it'll hesitate when I rev it up in neutral after its warmed up, only when I give it wot.
post #7 of 25 Old June 17th, 2012, 11:31 AM Thread Starter
Sammy8172's Avatar
I also replaced the maf like 2 weeks ago not to mention it runs like shit without it so I'm pretty sure it's good. I'm gonna check my 02s sometime tomorrow when I get a chance I'll keep this updated. I'll probably post a video sometime today
post #8 of 25 Old June 17th, 2012, 06:57 PM
Try running a can of sea foam in the tank. When i let my car sit for a winter it was sputtery like crazy. Had to make sure all the crap was run out of it. Fresh tank of 91 and half a can of sea foam in the tank did the trick. Cleaned it right out. Other than that try replacing the front 02's. Bad injectors? Pump could be all condensationy from sitting and it may be messed up. Lots of options here haha.
Pi swapped/MHS 2vrb1 Cams/BBK Off-Road Xpipe/Magnaflow Magnapacks/B & M Pro ripper shifter/Eibach Pro kit/BBK CAI/18" FR500s/4.10 gears/Trick Flow Plenum
275rwhp/297rwtq
BigSmith is offline
post #9 of 25 Old June 17th, 2012, 07:09 PM Thread Starter
Sammy8172's Avatar
Yeah I've been pumping premium since I got it and I've gone through 2 cans of seafoam. I changed the fuel pump, and I've done the fuel filter twice since I got it a few weeks ago. I'm gonna check the o2 sensors but if that's not my issue I may just end up removing my injectors and send them off for a deep clean and hope that's my issue. Should the car be doing anything differently when I remove the iat sensor from the intake while it's on? Or the other sensor on the intake mani? It doesn't make any difference and I'm starting to think one of those sensors could be faulty somehow.
post #10 of 25 Old June 19th, 2012, 10:16 PM
Wires priobably need replaced.
Sent from my myTouch_4G_Slide using AutoGuide.com App
1998 GT. Headers with catless X-pipe into flowmasters. CAI. Cobra wheels 17x9 with 245/40's and 17x10.5 with 275/40's. 04 GT leather interior.
98REDGT is offline
post #11 of 25 Old June 20th, 2012, 05:09 AM
cornfedgt's Avatar
wires and plugs
cornfedgt is offline
post #12 of 25 Old June 20th, 2012, 03:05 PM Thread Starter
Sammy8172's Avatar
I already changed the wires and plugs. Any way my coil packs could be causing this?
post #13 of 25 Old June 20th, 2012, 03:33 PM
cornfedgt's Avatar
Its possible
Sent from my LG-US670 using AutoGuide.Com Free App
CAI, pypes o/r x-pipe, Magnaflow Magnapack mufflers and 3.73s to come
4.6l 4v build coming soon
post #14 of 25 Old June 29th, 2012, 05:30 PM
esxtreme's Avatar
I have same problem after 30-45. 96 gt. Replaced everything also. Replacing o2s now. How to reset? O2s were only codes came up. Car gets to be barely driveable.
Sent from my LGL45C using AutoGuide.Com Free App
esxtreme is offline
post #15 of 25 Old June 29th, 2012, 06:46 PM
Got to go FASTER
Need to check all vacuum lines, especially the fuel pressure regulator. Start with basics. Matter of fact it being a 98 I would replace them all anyway.
wbacon8780 is offline
post #16 of 25 Old June 29th, 2012, 08:01 PM
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
Have you replaced the coil packs mine would do this after replacing the coil packs with 100% known good ones it went away. But you should check fuel pressure as well.
[COLOR="red"][SIZE="5"]MM FOBRA CLUB MEMBER #1[/SIZE][/COLOR]
1989Gt. is offline
post #17 of 25 Old June 29th, 2012, 09:36 PM
esxtreme's Avatar
My coils, iac, tps, all vac lines, o2, fuel filter, plugs, wires, PVC. Driving me crazy. Fuel pressure check next. But think o2s helped.
esxtreme is offline
post #18 of 25 Old June 30th, 2012, 03:34 AM Thread Starter
Sammy8172's Avatar
I ended up just removing my o2s and it helped alot. It'll actually move after its all warmed up to normal temp on wot. Just running extremely rich now..I'm replacing them both tomorrow. Planning on doing my coil packs too since mine are original, maybe another fuel filter change for me just cause the car was sitting for so long. That'd be my third one in 2 months lol..
post #19 of 25 Old June 30th, 2012, 12:37 PM
esxtreme's Avatar
O2 no help. After bout 60 miles, as long as its over 2k. Let off throttle a c#%t hair an car does not respond bogs.hope u find wat has yours.
esxtreme is offline
post #20 of 25 Old June 30th, 2012, 12:56 PM
p4ndiamond's Avatar
i would check the intake track mine is doing the same exact thing recently after i relocked my maf. goes wayyyy lean .
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Pi intake Hitech stage 2 cam, Vortech V7-JT Alum drive shaft. Lowering kit x2 ball joints Koni DA, H&R Super race spring LCA "
p4ndiamond is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/266577-98-gt-bogging-wot.html
Ford Mustang Forums - View Profile: 96redhotgt This thread Refback November 2nd, 2012 06:32 PM
