problem with 98 GT auto
Old June 29th, 2007, 11:27 PM   #1
1998 Mustang GT
Need to hit the track
RandoGT is on a distinguished road
this problem just occured today. not sure why but i was getting into my neighborhood and i stopped at a stop and heard a locking sound in the rear (i suppose), then when i go, i don't even bring it past 2000 rpm and for a second it felt like i lost traction and the car bucked a tiny bit and my friends and i could feel it. i thought it might be something in the rear so i got out and checked at my house but didn't see anything wrong. it only happens when i'm turning left (well, mostly) a few times turning right and barely ever when going straight. also, it only happens in the low low RPMs.
so, when coming to a stop, a locking sound and then going there's a slight buck and feels like loss of traction and makes a skipping sound.
HELP PLEASE
thanks
Old June 30th, 2007, 12:46 AM   #2
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
i had similar problems with my chevy. I fixed it by selling the car to a used car lot.
I hope they crushed her. Apoligies if some smuck bought her, but all the noises in the suspension, and whatever the noise is that RandoGT said shoulda been signs to run
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old June 30th, 2007, 01:28 AM   #3
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
Did you check your trans fluid ? Fluids do not last forever, common sense goes a long way........If your fluid levels are ok you may need at worst a rebuild on the trans. , but that is no reason to run !!!!!!!
Old June 30th, 2007, 11:50 PM   #4
1998 Mustang GT
well, i just had a tune up not too long ago and changed all the fluids, got a new rear differential and everything. not sure what's wrong with it. i didn't even notice it today except for once. so if you guys know any good advice, i'll take anything. and when i bought it, everything was perfectly fine and it's only in the low rpm levels that it does that stuff so yeah
Old June 30th, 2007, 11:52 PM   #5
Proud American
MustangMatt96GT's Avatar
T-loc clutches slipping? I have no clue!!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old July 1st, 2007, 12:29 AM   #6
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
It is your rearend. I solved this exact same problem by draining the rearend, and filling it with 100% Lucas synthetic oil. I have had no problems since.
Old July 1st, 2007, 08:32 AM   #7
1998 Mustang GT
seems like it might be the transmission, when coming to a stop there's a locking sound every now and then, i suppose that it's having trouble coming back into first gear
Old July 1st, 2007, 02:44 PM   #8
IBEATU
stanglifemike's Avatar
06 GT, 98 GT, & 93 Notch
stanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nice
Sounds like a slipping tranny to me.
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
Old July 5th, 2007, 10:59 PM   #9
ujslost's Avatar
This might be totally wrong, but something to check. Check to make sure the drive shaft bolts are tight and that the rear upper and lower control arm bolts are tight. Casper mentioned once that the control arm bolts are common both front and rear on these cars for needing to be tightened .
Old July 5th, 2007, 11:12 PM   #10
The Hammer
G.T. Rags's Avatar
Millenium Falcon
this is also a shot in the dark, but what about the tranni mounts.
Old July 5th, 2007, 11:16 PM   #11
ujslost's Avatar
yeah, didnt think about that , but good possiblility
Old July 7th, 2007, 08:27 PM   #12
djb98gt is on a distinguished road
If I read correctly you said it has traction issues when you turn left. When this happens does it feel like the suspension is starting to bind and then the tire chirps and it releases this tension force? If so, it is your traction loc causing this issue. You might have the wrong fluid in it.
Good Luck!
314RWHP 343RWTQ
NON PI HEADS 8 PSI P-1SC W 3CORE I/C
03 IRS, TREMEC 3550, JBA SHORTIE'S
MM SUSPENSION, BORLA STINGERS
BASSANI CATTED X
Old July 7th, 2007, 10:01 PM   #13
ujslost's Avatar
did you put friction modifier in the rear end. it has to have that for the t loc to work right.
Threads Similar to: problem with 98 GT auto
Auto for Auto swap ?s RandoGT 96-98 17 February 19th, 2012 02:42 AM
Shifting problem and noise on auto after tune F350toGTstang 2005 - 2010 14 September 18th, 2007 12:40 PM
Auto Trans Problem - Stuck in Park on my AOD Sir Charles 96-98 10 July 10th, 2007 10:03 PM
Problem with my auto stepfaster2000 V6 Mustangs 2 March 28th, 2007 12:45 AM
