bosch o2 sensor heater issues
Old June 25th, 2006, 03:09 PM   #1
mustang_montana is on a distinguished road
trying to figure out the deal with my o2s not heating up on their own. everything worked fine way back before i fucked around with the h pipe and changed the o2s. ive heard boschs dont heat up as fast as the factory ford ones. by no means are the boschs cheap so ill be pissed if they are the culprit. the only other thing would be a faulty o2 harness, which= pain in the arse to replace, or a short somewhere...which i doubt cause the fuses are good last i checked. what o2 sensors do you guys run? ever have any issues with them not heating up? i dont have longtubes, which people have major o2 sensor issues when using the bosch, cause they heat up from the exhaust mostly.
Old June 25th, 2006, 05:04 PM   #2
mdvaldosta's Avatar
11.47@120.58
Theirs nothing wrong with Bosche, their the main manufacturer of o2 sensors... and I've got a set on my Mustang.
Old June 25th, 2006, 06:50 PM   #3
hmm, looks like im replacing the harness then, cause everything else checks out. i might get a couple of new o2s, like the stock widebands and see if they work.
Threads Similar to: bosch o2 sensor heater issues
AC & Heater now that it is winter, my heater doesn't wor Kingcater 5.0 Mustangs 13 January 22nd, 2008 01:33 AM
heater mxnate116 Audio/Video 0 November 4th, 2007 08:55 PM
Bosch "Iridium" 4-prong spark plugs - Anybody use TCSoff 2005 - 2010 5 July 11th, 2007 10:19 PM
Bosch Platinum +4 Plugs Patterson98GT 96-98 16 April 30th, 2007 12:07 PM
Bosch Platinum +4 plugs Juggalo_X V6 Mustangs 20 April 24th, 2007 02:32 PM
