Discussing trouble codes...HELP!!! in the 96-98 Forum. alright guys i have three reoccuring troubles codes that falsh on and off for no ...
Old July 1st, 2007, 12:41 AM   #1
alright guys i have three reoccuring troubles codes that falsh on and off for no apparrent reason and with no particular pattern. i retrieved the freeze frame data for the first and will put it in behind it, followed by the second and third code, than the I/M status.
1. P1130--Lack of HOS2S11 Swithch - Fuel Trim at Limit
Fuel System 1 - CL, using H02S
Fuel System 2 - N/A
Calc. Load (%) - 39.2
Coolant (*F)- 190
ST FTRM1(%)- 32.8
LT FTRM1(%) - 24.9
ST FTRM2(%) - -1.5
LT FTRM2(%) - -0.7
Engine RPM- 2189
Veh. Speed (MPH) - 67
2. P1131--Lack of H0S11 Switch - Sens Indicates Lean
3. P0171--System Too Lean (Bank 1)
I/M Status
MIL Status- on
Misfire Moniter - ok
Fuel System Monitor - ok
Comp. Compnent- ok
Catalyst Monitor - ok
Htd Catalyst - N/A
Evap System Monitor - N/A
Sec. Air Monitor - N/A
A/C Refrig. Monitor - N/A
Oxygen Sens Monitor - ok
Oxygen Sens Htr- ok
EGR System - ok
98 GT, K&N Cold Air, Steeda Timing Adjuster & Underdrive Pulleys, MSD Spark Control
3.73 Gears, MagnaFlow Highflow Cats, X-Pipe, and Mufflers, Tri-Ax Short Throw , King Cobra Clutch, W Gauges, Bullitt Wheels
Tokiko 5-Way with C/C Plates, sub-frame con.
Old July 9th, 2007, 05:00 PM   #2
MM Ninja / Site Moderator
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
replace your upstream O2 sensors
Modded Autos Join today, All makes all models
Originally Posted by drgnracin72 View Post
fat girls dont expect dick, they apreciate it...
Old July 9th, 2007, 06:00 PM   #3
ujslost's Avatar
yep! but the only one thats throwing codes is bank 1.. HOS stands for Heated Oxygen Sensor btw.
http://www.moddedmustangs.com/forums/vehicle-classifieds/86839-wtt-90-lx-hatch-red-black-north-alabama.html#post1394801
Old July 9th, 2007, 06:12 PM   #4
Juggalo_X's Avatar
14+@Slow
bank one would be cyl 1-4 try replacing that one first but these are definitely O2 related issues. do you have the rear o2's installed as well or deleted?
Old July 10th, 2007, 09:38 PM   #5
yah i replaced the bank 1 downstream h02 sensors shortly afer these dumb codes started poppin up a while ago. ill def. look into the upstream sensors as well. i haven't deleted the downstreams yet cause i haven't decided on a chip. i noticed one of you is sniper tuned, thats what ive been lookin into here lately. me and my sis (02 GT) would go in halfs cause it says it can store files for two didfferent cars. is this true? is it really as customizable as it appears and would you recomommend it. don't be afraid to mention anything you don't like, thats the kinda stuff i need to know
Old July 10th, 2007, 09:42 PM   #6
my dad said something about maybe there a header leak on bank 1 cause the guy that i bought the car from had takin them off to put something on the car. he said he just tightened them up but didn't torque them. my dad said something about bank 1 may be "flashing" from false oxygen?
Old July 10th, 2007, 10:06 PM   #7
Juggalo_X's Avatar
14+@Slow
a bad header leak will throw a lean code. torque those down.
Threads Similar to: trouble codes...HELP!!!
Trouble Codes GTsetGO Modular Mustangs 15 December 4th, 2007 03:13 PM
SCT Trouble Codes! What to do? wormster00 2005+ 10 July 6th, 2007 03:14 PM
Trouble codes bigbadtalontsi 5.0 Mustangs 3 March 30th, 2007 12:26 AM
trouble codes scubasteve041186 V6 Mustangs 2 December 31st, 2006 11:19 AM
trouble codes.... stang fanatic General Tech 0 July 6th, 2006 11:36 PM
