Struts.
Anybody replace thier struts. I'm getting a clunking sometime rattle sound from the front. Both lower ball joints are new. Outer tie rods , both changed by me about 3 years ago. Pads and rotors are 2 years old. I'm thinking inner tie rod or struts. Or outer ties again ? Car has about 98,000 miles. Walt.
I change them all the time. What do you need to know?
Custom engine built from Super Six, Cam from Delk performance, Custom Novi 2000 in the works. My Car www.supersixmotorsports.com www.bc-automotive.com/ |
I just wanted to know if I can do it myself. Or what to do. The repair book says to chain , and or , jack up the lower control arm to keep everything in place. I assume the spindle and rotor will drop down, but my concern is can I compress the strut with out any special tools ? Walt.
Compressing the strut is easy. You don't have to compress it though. I always jack the car up a good distance and then put a jack under the A-arm. Undo the bolt on top and slowly lower the jack to take tension off the strut. I then remove the two bolts connecting it to the spindle. Remove strut and them install the new one.
Proud American
Struts are easy! Took me about 3 hours to do mine! Hardest part was the nut on top!
Thanks.
Thanks for the advice. Hoping to get to somethings that I have'nt had time for. Walt.
Threads Similar to: Struts.
| What struts to use? | smithbuilt24 | 99-04 | 11 | November 5th, 2007 04:06 PM |
| struts... | Sickstick | General Tech | 1 | May 18th, 2007 09:08 AM |
| struts | patwrecked | General Tech | 1 | April 24th, 2007 11:30 PM |
| Fun with struts | OTreborO | General Tech | 0 | May 5th, 2006 04:20 PM |
| struts | zhunter | General Tech | 4 | March 24th, 2006 05:51 PM |
