Theft light blinking , car won't start - Forums at Modded Mustangs
post #1 of 12 Old July 15th, 2012, 03:39 PM Thread Starter
gtfear's Avatar
Alright so I have a 97 mustang .I went outside this morning to go to work, the car started fine then died within a few seconds then the theft light started flashing pretty fast .and now it won't start at all( turns over fine ) . If I unhook the positive battery cable and hook it right back up the car will start and die . Thn won't start again till I repeat the process . And the light is flaming the whole time . With the car starting when unhooking then hooking the batter cable back up I assume it's not a blown fuse ? . I figure it's something to do with the PATS system . I do not have another key , and car ran fine yesterday . Anyone have any solutions ??
gtfear is offline
post #2 of 12 Old July 15th, 2012, 04:14 PM
mustangforever97's Avatar
how long have you had the car
pro 5.0, off-road hpipe,flowmaster 40's,msd coils,pretty much stock 94gt "sold" 96gt "wrecked" 97gt "sold" 98gt "wrecked" 01gt "traded" now 4v all the way
mustangforever97 is offline
post #3 of 12 Old July 15th, 2012, 04:21 PM Thread Starter
gtfear's Avatar
Bout 2 years never had a problem . The car actually starts every time then dies but you gotta turn the key all the way off then on and it'll start . Just don't stay running
gtfear is offline
post #4 of 12 Old July 15th, 2012, 05:28 PM
my 97 did it to me before when the battery dided we charged it and it wouldnt start and im tearing the fuse box apart under the dash and i seen that there was an aftermarket sucurity system and a toggle switch was missing so i wired in a toggle switch and fucked with it and it started right up
post #5 of 12 Old July 15th, 2012, 06:45 PM
Green4.6's Avatar
Sounds like your key is bad.
Pacific Green 96 Gt
Green4.6 is offline
post #6 of 12 Old July 15th, 2012, 09:46 PM Thread Starter
gtfear's Avatar
If the key is bad , would the car even start at all ?
gtfear is offline
post #7 of 12 Old July 18th, 2012, 03:55 PM
Vect0rmask's Avatar
Send a message via Yahoo to Vect0rmask
If the key is bad the car might start, but then die from the anti-theft. I can't remember the exact number but I read about an on-off cycle you can do with the key to turn off PATS. I haven't tested it but it might work if you can find the procedure.
Vect0rmask is offline
post #8 of 12 Old July 18th, 2012, 04:59 PM
xandraxal's Avatar
Yes, if key is bad, car will start, then die after 2 seconds. It happened to me
xandraxal is offline
post #9 of 12 Old July 18th, 2012, 05:00 PM
Rollin' 18/ pushin' 2
97S281's Avatar
iTrader: 18 reviews
You can disable the PATS with a tuner.
MODS IN GARAGE
All SVO'D UP
97S281 is offline
post #10 of 12 Old July 20th, 2012, 08:46 PM
97GT4.6's Avatar
iTrader: 5 reviews
Send a message via AIM to 97GT4.6
+1.. my 97 had that problem.. it would do it randomly, and it was frustrating.. so I just had the tuner Disable PATS and I haven't had a problem since.
97GT4.6 is offline
post #11 of 12 Old July 21st, 2012, 01:11 PM
97S281's Avatar
iTrader: 18 reviews
Yeah, I was having a problem with mine and did the same thing. It was so much easier than trying to run the problem down. Only thing was after disabling it the theft light would blink for about 2 minutes after I started the car. Finally I just pulled the bulb out.
MODS IN GARAGE
All SVO'D UP
97S281 is offline
post #12 of 12 Old August 3rd, 2012, 07:52 AM
Prior to 03 the vehicle was allowed to crank but fuel delivery was disabled. After 03 ford incorporated the PATS system into the starting system. Get a locksmith to program a new key to your vehicle.
jweast is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/269810-theft-light-blinking-car-wont-start.html
Thread Need advice!! My theft light it blinking | Forums at Modded Mustangs | BoardReader This thread Refback February 14th, 2013 06:34 PM
