1998 Mustang GT
whats the right sprak plug for me
what are my options on spark plugs for a full PI swapped 98 GT with nitrious 75-100 shot...and what to gap them at
Purple Power
96 Mustang GT
Ngk tr6 gapped at .030
1998 Mustang GT
tr6? arent those only one step colder?...i would think at least a 2 step colder for the bump in compression and n20...
My phone has vtec
1996 GT/ 2008 GT Vert
4jz swap with 142 stickers
+1, but id run the gap a little larger if it was me.
CMS Stage One cams, PI heads, PI intake, NPI bottom end, FRPP 3.73's, FRPP C Springs, Tokico HP's, and other bolt ons and visuals. ![]() |
Purple Power
96 Mustang GT
Because of the nitrous, id gap smaller...just me, im personally not a fan of nitrous
My phone has vtec
Yeah you make a point. I'm also not a fan of nitrous either. OP run a copper plug if you're using nitrous.
1998 Mustang GT
Purple Power
96 Mustang GT
He means dont run platinum plug. And I am of the school that says you dont need plug 2 steps colder until you run 20lb of boost or a 200 shot if nos
My phone has vtec
Buy a TR6 plug. It should be in an NGK V-Power package. Do NOT run a TR6GP.
Exactly, 100% agreed on that.
1998 Mustang GT
alright sounds good then tr6 it is now you guys are saying .30 gap what about when its not be sprayed how will that affect drivabilty and if i wasnt plannign on spraying right away would you say for gap with the swap and premium fuel with a tune??
1998 Mustang GT
and something else i dont get why would one use a smaller gap when running spray would you want a bigger arc because of all the extra fuel and oxy molecules or does that make it weaker cause it has to arc futher???
12.41@114
If you run too big of a gap with FI it will cause spark blowout. I run all my FI set-ups with a gap of .028-.032
You won't notice much change at all in driveability.
MM FOBRA CLUB CO-FOUNDER
Hooo Ha Ha
I would recommend autolite 103's
Your going to need to gap them around .030 Worked fine when I used to spray my car.
![]() 496rwhp 580rwtq @ 12psi 76mm Turbo 5.4 swap #turbo2v www.JPCracing.com 410-729-0005 |
1998 Mustang GT
i think i would be more comfortable with a 2 step colder plug, what would they be for NGK and Autolite?
1998 Mustang GT
My phone has vtec
NGK would be a TR7, no idea on the Autolites though.
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
NGK has the TR7IX and the BR7EF. Motorcraft has the AWSFA-12C and the AGSF-12FM1. Denso has the T22EP-U (does not have a resistor).
My recommendation is to start with a colder plug, make a pull, check the "color" to see where you're at, then adjust heat ranges from there.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
1998 Mustang GT
sounds good guys thank you
Threads Similar to: whats the right sprak plug for me
| Champion Spark Plug 7989 Double Platinum Plug | UNVMYGT | 2005 - 2010 | 6 | November 24th, 2011 01:50 AM |
| single plug head on dual plug motor? | daviddunivan | 2.3 Mustangs | 4 | April 5th, 2011 06:03 PM |
| Laser sprak plugs? | 1FF | The Clubhouse | 6 | August 3rd, 2009 11:29 AM |
| ok whats this plug | dark-samurai2 | V6 Mustangs | 14 | October 20th, 2007 07:17 AM |
| sprak plugs | notsoslow50 | 5.0 Mustangs | 8 | August 22nd, 2007 02:59 PM |
