Slip-Slidin Away!!
Old July 4th, 2007, 06:30 PM   #1
naughty girl 98 is on a distinguished road
Slip-Slidin Away!!
[img]My 98 SVT Cobra is running really good after all the mods we have done to it. Right now I am having a problem getting traction at the line. I broke loose some Mickey T's 275/60/15's. I didn't think I had the low end torque for that. I have 17 inch wheels on my car stock. Should I go with 17's to drag with or 15's? Maybe I just didn't heat them up enough. Anybody have any advice for a girl who wants to race and win so bad it hurts? [/img]
Old July 4th, 2007, 06:31 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
well for starters .. what are your mods?
Old July 4th, 2007, 06:38 PM   #3
I put a cold air intake, shorty headers, an X-pipe, a King Cobra clutch, changed to 4:10 gears and put a short shifter on it. 2 1/2 inch Flowmaster (American Thunder) exhaust.
Old July 4th, 2007, 06:40 PM   #4
Proud American
MustangMatt96GT's Avatar
Thats what 4.10s will do for you! lol drop the tire pressure a bit and and heat them up more and launch at a lower RPM!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old July 4th, 2007, 06:43 PM   #5
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
try some good aftermarket upper and lower control arms and a set of full lenght sub frame connectors.
that should do the trick
Old July 4th, 2007, 06:46 PM   #6
Old July 4th, 2007, 06:48 PM   #7
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
we already know that much.
Old July 4th, 2007, 06:51 PM   #8
Proud American
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 4th, 2007, 06:54 PM   #9
How low should I go with the pressure? I went down to 20psi. I could leave the line at 5 and I was all over the place. I can leave at 4 and still spin.
Old July 4th, 2007, 06:55 PM   #10
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
your going to continue to spin until you get some suspension mods under there...
there is no point in having a fast car if you can't get it to hook.
Old July 4th, 2007, 06:59 PM   #11
Proud American
Well I leave the line at 2200-2400 and still spin with 2.73s in my car! lol and I would recommend more like 13-15 PSI in your MT!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 4th, 2007, 07:00 PM   #12
I agree with that! Do you think the tire size is about right? 275/60/15's or should I try something else, and how low can you go on tire pressure? I do have some upper and lower control arms ordered. They should be here Fri. The next time I can get to the track is next weekend though.
Old July 4th, 2007, 07:03 PM   #13
Proud American
Well that tire should be fine for you! and I know of guys running around 8-9 in there MT! What brand lower and upper contol arms did you buy? And you have to remember that racing at the track is a lot different than on the streets! My track always seems to be really slick!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 4th, 2007, 07:04 PM   #14
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
you should try these
(don't use slicks on a stock rear end please)
Old July 4th, 2007, 07:07 PM   #15
Proud American
Whose cobra is that?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 4th, 2007, 07:14 PM   #16
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
a friend of mines.
Old July 4th, 2007, 07:17 PM   #17
What I am trying to do is stay in the factory stock class according to the NMRA rules. I can't run total slicks on my car. My MT's are the ET Street Radials. The contol arms are from Hotchis (stock repacement non-adj.)
Old July 4th, 2007, 07:20 PM   #18
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
you could still get the sub frame connectors..
that will help out... taking off your front sway bar will help too
Old July 4th, 2007, 07:23 PM   #19
I'm thinking about changing to a 275/50/17 tire. My car seems to react slower with the larger diameter tires than my 245/45/17 street tires. Is it a good idea to switch to a smaller diameter tire, and still use the MT Street drag radial?
Old July 4th, 2007, 07:26 PM   #20
Do you know if the sub frame connectors are allowed in that class?
Threads Similar to: Slip-Slidin Away!!
slip yoke terribleonexx88 5.0 Mustangs 3 November 3rd, 2007 01:51 PM
clarifications from joe slip ups joejoe8455 The Clubhouse 41 June 25th, 2007 10:38 AM
limited slip? cpork V6 Mustangs 7 May 9th, 2007 02:36 PM
clutch slip kreil45 5.0 Mustangs 11 April 6th, 2007 12:43 AM
slip yoke?? dstang03 99-04 0 May 22nd, 2006 12:07 AM
