4.6 cold start engine knock
Old July 4th, 2007, 10:19 PM   #1
jasons_98gt's Avatar
1998 mustang GT
jasons_98gt is on a distinguished road
Send a message via Yahoo to jasons_98gt
hey everyone new to the forum here....just need some help here got a 98 gt and when the car sits for 5 or 6 hours even overnight when i start it it makes a clacking sound or light knock for only about 30 seconds or so...sometimes it wont even do it...so far i did a compression check and im getting 160lbs buildup is fast which is a good sound i did a fuel, oil, and coolant pressure check and they and they all are in specs now i heard of piston slap issues and was wondering if that could be it??? the car has been well taken care of maintance wise as im the second owner and got reciepts from past oil changes new air filters fuel filters pcv valves alot of people skip those i bought it with 82k and it now has 130k the noise has not gotten worse over mileage so im just wondering if its normal for this engine? i also use midgrade gas and fill it with premium 2 times a month or use a good injector cleaner and i been using castrol 5-30 non synthetic i even tried synthetic and 10-30 with no change in the noise i appreciate anyones suggestions or answers
thanks
Old July 5th, 2007, 11:49 PM   #2
ujslost's Avatar
Oil pump loosing its prime?
For how many miles has it done this?
Old July 7th, 2007, 02:09 PM   #3
bbrewer03's Avatar
1997 Mustang GT
bbrewer03 is on a distinguished road
My 97 has a chatter that is worse when its cold. I know some people get a chatter and a knock mixed up. I believe mine could be a loose rocker or maybe just worn valves. Anyways if it is a knock it couldnt be too good.
Good luck.
1997 GT
Cobra R Hood, Cobra Front bumper, MSD plug wires, Tailights, Projector headlights, 18x9 chrome bullet wheels in front and 18x10s in back, Tunable Induction Cold air intake, flowmaster mufflers. 4.10 Gears.
Old July 7th, 2007, 02:23 PM   #4
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
my car makes a noise like that too. My clutch is on its way out and my throw out bearing screams like a bitch. When it's cold it's real bad. I't been going on since i got the car, and now the clutch is actually starting to not catch 1st. She only makes noise when she cold starts though, and maybe a lil hum thats unnoticeable while she's warm.
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old July 7th, 2007, 02:55 PM   #5
bbrewer03's Avatar
1997 Mustang GT
LOL, same here. Going through a drive through is annoying as hell. Its bad when it drowns out your exhaust. I really need to ordr a new clutch. 150k is getting close to its limit im sure.
1997 GT
Old July 7th, 2007, 03:02 PM   #6
G.T. Rags's Avatar
Millenium Falcon
yea, considering my car doesn't make that much noise. I can go through drive through's just fine.
Old July 7th, 2007, 03:37 PM   #7
ujslost's Avatar
mine throw out bearing rattles too. but seems like its a little quieter since i put the clutch quadrant and firewall adjuster on it. probly just a little more pressure on it now.
Old July 7th, 2007, 03:55 PM   #8
G.T. Rags's Avatar
Millenium Falcon
ujslost, how much did u lower u car? Was the kit expensive? Hard to do urself? My tec refuses to do it cause he said it'll mess with the allignment, shops will give me crap about getting it allighned, might not even touch it. Any noises?
Old July 7th, 2007, 04:08 PM   #9
ujslost's Avatar
only noise since lowering it the drive shaft hits the ebrake tab on the bottom of the floor if I get on it real hard with a passenger.
I used the eibach prokit. (1.5inces) Costs about $220 and I put it in myself in about 2 hours including ball joints. Any alignment shop that will not touch it afterwards is just incompetent . You might want to get CC plates but probly wont need them unless you get the eibach sport line kit. (2.0 inches)
Threads Similar to: 4.6 cold start engine knock
problem with cold start 6banger96 V6 Mustangs 5 November 7th, 2007 04:49 PM
Slight Engine Knock? VegasGT 2005 - 2010 2 September 27th, 2006 04:18 AM
Engine No-Start Pony Boy 99-04 2 September 11th, 2006 04:41 PM
should my car be stalling/surging on cold start with a cam? WhiTeFoX5point0 5.0 Mustangs 4 August 26th, 2006 01:42 PM
5.8/351 Windsor Cold Start Stall thunderbird885cc All Other Vehicles 2 July 3rd, 2006 01:27 AM
