Center console gets really hot
Old July 6th, 2007, 02:34 AM   #1
ckjacobus is on a distinguished road
Well I thought I already posted this but I guess it got erased or I don't remember where I put it. Anyway, my center console gets really really hot to the touch when driving. I cannot figure out where it is coming from. It is hot between the shifter and the compartment right behind the ash tray. I have already flushed my transmission with new fluid but it still gets really hot. My motor doesn't overheat but you can feel the heat coming out from under the car. Is this a sign of something bad in my transmission? As a matter of fact the motor itself seems really hot when it is running if you open the hood but it never overheats or even gets hot according to the gauge. Please help with any thoughts.
Chris
Old July 6th, 2007, 02:43 AM   #2
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
do u have cats or an o/r pipe. Ur converters may be clogged and in need of a replacement. Next time it happens, pull over, leave the car running, put it in park or pull the ebrake, dunno if ur 5spd or not, and look under that car. If u have cats and there glowing red thats ur problem
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old July 6th, 2007, 02:50 AM   #3
I will check that for sure, that would be nice if that was the problem because the is the last piece of my exhaust that I am changing, I am adding an aftermarket H pipe so maybe they are just clogged. I will try that, but still open to any other ideas that people might have.
96 GT, CAI, 75mm TB, PP Plenum, typhoon intake manifold, BBK shorties, flowmaster catack, UPR x pipe, FRPP 9mm race wires, complete PI swap
Old July 7th, 2007, 12:54 PM   #4
ujslost's Avatar
Check that the rubber boot under the shifter is actuall sealed off and bolted to the floor pan, if not you will get a shit load of heat in the console.
Old July 7th, 2007, 08:28 PM   #5
Ryan Paymaster's Avatar
1996 Ford SVT Cobra
13.36@102
Ryan Paymaster will become famous soon enough
Send a message via ICQ to Ryan Paymaster Send a message via AIM to Ryan Paymaster Send a message via MSN to Ryan Paymaster Send a message via Yahoo to Ryan Paymaster
Mine doesn't get incredibly scalding hot, but it does get damn warm after driving the car, especially hard.
If I touch the floor or plastic, I can feel warmth. If I open up the ash tray thing and touch the metal it is actually hot. Not like "Damn, I should stop touching this hot," but still hot.
This just may be heat from your exhaust / transmission / etc. I don't have cats for what its worth.
Old July 7th, 2007, 08:56 PM   #6
ujslost's Avatar
no cats should actually make it cooler.
Old July 8th, 2007, 09:15 PM   #7
Well I am replacing the cats this weekend with new x pipe and I also looked at the shifter and the boot is ripped where the bolts are. Can I buy that part at a dealership. It looks like there is some kind of tacky substance on it like the owner before me tried to glue it back down.
Old July 8th, 2007, 09:55 PM   #8
ujslost's Avatar
96 gt? i will get you a base part number in a few mins. should be able to get that part still.
Old July 8th, 2007, 09:57 PM   #9
Proud American
MustangMatt96GT's Avatar
Yeah it should be a part that you could get from your ford dealership! and it should cut down the heat in your car!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old July 8th, 2007, 10:11 PM   #10
ujslost's Avatar
7277 Gearshift Lever Boot
see if that will fix you up.
It will fix that heat problem.
Threads Similar to: Center console gets really hot
My Center Console... ChrisJ Audio/Video 76 December 20th, 2011 10:33 PM
No center console jake1191 5.0 Mustangs 2 August 24th, 2007 11:08 PM
center console wadepetersen V6 Mustangs 6 July 24th, 2007 09:20 AM
center console wadepetersen Visual 3 July 20th, 2007 08:57 PM
Center Console hawaiianbrian78 V6 Mustangs 1 November 10th, 2006 12:08 AM
