1997 Mustang Cobra
1/8 - 8.89@86mph
![]() iTrader: 1 reviews
Rear brakes....
Ok I know some rear disc brake systems have a trick to them for the parking brake. dose anyone know if theres a trick to my Cobras rear brakes? Iam getting ready to replace all 4 brake pads all around and figured id ask before i did something. lol I know it was a pain in the buttox when we chaged the rears on my moms 96 regal. any tips from experience?
![]() Modifications and pics in my Garage... Reps Appreciated!
MM's Coffee Addict
I don't think there is Chris. Just release it and you should be set I would believe. I'm gearing up to do all four corners with the SSBC pads/discs I have had lying around for 4 months now. If I beat you to it, I'll letcha know what problems if any I run into. If you do yours soon (ie, before I do, lol) and there turns out to be some complicating trick to our rears, do let me know man, I'd appreciate it. But just looking at them, they don't look any different in setup than any other rear-disc setup I've worked on in the past.
![]() Vortech V2, intercooled @ 10psi. Maximum Motorsports supsension goodie bag car less roll cage. Built '04 IRS. Hodge-podge of Roush/Stalker panels. |
1997 Mustang Cobra
1/8 - 8.89@86mph
lol try working on a buick regals rear brakes... lol WHAT A PAIN! you need several special tools to undo the damn e brake mechanism. lol I do hope ford is smarter lol.... but yeah if i tear into them ill post it up. my hawk pads should be here the 11th...
MM's Coffee Addict
cool man. good luck. i too hope it only takes me an hour. i've done brake work on my dad's 95 lincoln mark viii which is basically 75% of what our cobras are made of, so i hope our cars are as easy to do as his was.
oh and I finally got some springs on my car... i'll have to post up some pics soon. the stance is so much improved, it no longer looks like its "floating" 8 inches off the ground. you know what i'm talking about. looks so much better it's incredible. alright, well again, g'luck with the brakes.
1997 Mustang Cobra
1/8 - 8.89@86mph
lol thanks! what springs did ya get? did u put em in?
#6 | |
MM's Coffee Addict
Between the kit and paying my buddy to install it for me (in beers, and a fifth of Grey Goose, lol) I spend 300. Not too bad in my mind. I think I'm in money saving mode now. Next mod will be an x-pipe and possibly a better clutch, though gears are tempting.
Proud American
Man dont waste your money on anything else until you have 4.10 or 4.30s in there!!
#8 | |
MM's Coffee Addict
Proud American
Man I think that the 4V need the 4.30s! Hell I think my car could use 4.30s and still be alright with gas and DD! I just got my 4.10s and love them! And then once you have the gears in there you can get a new clutch and then get an O/R H with Flow 40s!
Just release the brake cable, if just putting pads on know that there is a "special tool" needed to compress the caliper.. These calipers have to screw in and press in at the same time. Just ask someone at the parts store for the cube shaped caliper tool for rear calipers. They cost around $10.
1986 Mustang GT t-top time piece! |
#11 | |
1997 Mustang Cobra
1/8 - 8.89@86mph
and mustang matt.... i have 4.10s and thats plenty! at 80 mph iam at 3000 RPMs and 1st gear is almost gone... lol oh and driving in the rain HAHA dont even think about it... lol
#13 | |
MM's Coffee Addict
MM's Coffee Addict
hey chris I posted a bunch of pics and a vid in the multimedia section - take a peek at the lowered car. wanna lend me your gears for ... ever? :wink
1997 Mustang Cobra
1/8 - 8.89@86mph
lol i still have my stock gears ill lend ya... only 75,000 miles on em lol
I've done rotors & brakes in all 4 corners of my 98' Cobra.
The cube tool that was mentioned above worked great for compressing the calipers! Now that brake cable did turn out to be a pain in the ass. The best way I found out for putting it back into the "U" shape holding braket was using a pair of vice grips and pulling it over. At the same time, you need to slide the little clip that holds in it place with your other hand. Its going to take some muscle and patience. Good luck!
98' Cobra BBK Pulleys Cold Air Intake w/ K&N B&M Short Shifter Slotted/Drilled Rotors |
1997 Mustang Cobra
1/8 - 8.89@86mph
oh dang... lol well thanks
#18 | |
MM's Coffee Addict
yeah I am pretty sure my rear left rotor has suffered disc runout, as it's startin to shake a little when i apply brake pressure - definitely a must do this weekend! i've seen those cube tools before but have no f'n clue as to how to use them - I've seen many a rear brake caliper compress with the turn of an allen wrench. was kinda hoping that'd be the case with ours (chris) but doesn't sound like it eh?
MM's Coffee Addict
hey chris - have you looked into getting stainless brake lines? i have, but have come up empty handed in finding a supplier for our cars. newer mustangs and the old 5.0s are ever so popular to find, but not for our cars, apparently. just wonderin if you've ever run across a set of 4 for sale somewhere online.
1997 Mustang Cobra
1/8 - 8.89@86mph
yeah they have them go to summit they sell em for our cars. but i dont want to get into that because it dose get time consuming haven to bleed the lines n rebleeding them and if you messed up there could be a air bubble n mess up the brakes...but ill do it sooner or later. i just HATE bleeding brakes! lol
allen wrench huh? ive always used a C clamp the compress the calipers (front)
Threads Similar to: Rear brakes....
| wat brakes? | VSR13 | V6 Mustangs | 11 | September 27th, 2007 01:41 AM |
| Help: Replacing dust boot on 03' mustang rear brakes | db | 99-04 | 3 | August 20th, 2007 12:45 AM |
| 5.0 rear disc brakes | sk8terben | 5.0 Mustangs | 2 | February 13th, 2007 02:54 PM |
| Rear Brakes | 97stanger | V6 Mustangs | 5 | February 1st, 2007 08:42 PM |
| Rear Brakes Squeeling | Bill | 5.0 Mustangs | 6 | January 16th, 2007 12:27 AM |
