TPS reading backwards
Old July 9th, 2007, 09:25 PM   #1
blakeasaurusrex is on a distinguished road
just like it says, back to square one with everything, the TPS is reading like 4v at idle and it goes down when u give it gas. isn't it supposed to go the OTHER way? in the book it says it should be at like 0.95-1.0 at idle and go up to 5v at full throttle..
i don't get whats wrong but i've replaced it and the same thing.. the original one was hopping all over, this one is more steady but its still wrong.. anyone know ?
1998 Mustang GT - Slow
Old July 10th, 2007, 08:01 AM   #2
neverfastenough1's Avatar
I have been racking my brain for the past 10 seconds, and the only thing I can think of is you got the wrong wires. I am sure it isn't but make sure its not reading ohms. See the reason I say it is the wrong wires is because it is a potentiometer. You have a ground on one end of a resistance and a hot wire on the other end. You have the wire going to the eec to tell it where the throttle is that is moved along that resistance when the throttle moves. If you have one probe on the eec wire and one on the hot wire it will read higher the closer the eec wire is to the ground on the resistance(idle) and less the further away it gets for ground (wot). Sort of like putting your battery in the trunk and hooking the ground to the body in the trunk. The body creates more resistance and the ground weakens before it gets to the sparkplugs and 02 sensors. Try that, switch wires.
Old July 10th, 2007, 02:54 PM   #3
ujslost's Avatar
what the book told you is right. i would conclude that you have a bad tps.
when they go bad usually they will show 5v at idle
Old July 10th, 2007, 11:29 PM   #4
He said it was new but you are right just because its new doesn't mean its good.
Old July 10th, 2007, 11:40 PM   #5
ujslost's Avatar
well in that case you are checking the orange and green wires correct?
Threads Similar to: TPS reading backwards
For your reading pleasure ... MeZ 99-04 22 July 30th, 2007 10:51 AM
WATER PUMP RUNNING BACKWARDS WITHOUT SMOG OR AC! ken5_0 5.0 Mustangs 11 May 6th, 2007 10:30 AM
Still reading cold YNOT 5.0 Mustangs 13 April 29th, 2007 07:49 PM
Jingle Bells Backwards FOR POINT SIX The Clubhouse 16 December 23rd, 2006 08:45 AM
Caster/Camber Plates Backwards? DC97Cobra General Tech 2 November 26th, 2005 12:04 PM
