HELP Speed Cal
Old July 10th, 2007, 07:41 PM   #1
Proud American
MustangMatt96GT's Avatar
HELP Speed Cal
Okay so I installed it as the instructions say to a T! But when I am driving all it does is move the speedometer to just above 10 MPH at whatever speed! I have it set for 4.44 gears because my speedometer was roughly 5 off before the gear swap!
The large DIP switch settings are: 1101000000
The small DIP switch settings are: 1000000
Any help is appricated!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old July 10th, 2007, 07:59 PM   #2
ujslost's Avatar
No idea here bro, never used a speed cal.
Old July 10th, 2007, 08:18 PM   #3
HMUSN's Avatar
iTrader: 9 reviews
http://www.dallasmustang.com/page/speedcal.inst.php
scroll down a tad
Old July 10th, 2007, 09:00 PM   #4
Proud American
THose are the instructions i used to install the thing! they are the exact same as the ones that came in the box except with pictures! Man I guess I am going to have to try switching things while I drive to see if anything will work!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 10th, 2007, 09:01 PM   #5
Proud American
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 10th, 2007, 09:05 PM   #6
HMUSN's Avatar
iTrader: 9 reviews
sounds like an install error.
Old July 10th, 2007, 09:07 PM   #7
Proud American
Ive installed it twice exactly how it says
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 10th, 2007, 09:12 PM   #8
HMUSN's Avatar
iTrader: 9 reviews
call them .
Old July 10th, 2007, 09:17 PM   #9
Proud American
I cant find a number and its 6 o'clock so i figure they are closed!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 10th, 2007, 09:28 PM   #10
68 dlxcoupe's Avatar
2004 Mach 1
13.30 @ 104.47
68 dlxcoupe is on a distinguished road
Send a message via AIM to 68 dlxcoupe
hey matt uhh well you got screwed outta money just like I did. Your car has a mechanical speedo and the Speedcal is meant for 99-04 gt's with the electronic vss. Its complete bs and I couldn't get my money back but yea. You need to get a 21 tooth or 22 tooth speedo gear to correct your problem. A Speedcal wont do jack with a mechanical speedo (96-98) Sorry bro hope this helps
http://www.moonshine-media.net/68dlx2.jpg
EAGLE SCOUTS OR GTFO
MyStangOpens (12:01:05 AM): honey nut for me
Old July 10th, 2007, 09:32 PM   #11
HMUSN's Avatar
iTrader: 9 reviews
ouch.. your right.. for some reason i thought he has a 98 GT..
you need to buy a speedo gear.. they are only like 10 bucks though
Old July 10th, 2007, 09:36 PM   #12
2004 Mach 1
13.30 @ 104.47
they arent even that. I got mine for a little under 2 bucks shipped to my door
Old July 10th, 2007, 09:41 PM   #13
Proud American
nope the speed cal will work with our cars! I did my research before I bough it! our trannys send out our speed via gear, but then it goes throught the VSS and then the VSS has magents in it and changes the mechanical portion into a electrical current that will change the speed o meter. I will be ginving them a call tommarow after work
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 10th, 2007, 09:45 PM   #14
2004 Mach 1
13.30 @ 104.47
I gotta 97 and I tried everything they told me and nothing worked and then they told me I didn't know what i was doing. LOL I don't believe in a speedo anyway, I gotta tach for a reason and I certainly dont use it for shift points. Good luck man hope they treat you better than they did me.
Old July 10th, 2007, 09:59 PM   #15
Proud American
yeah well I have to have a speedo! this is my DD and I dont have a clue wat speed I am going with the new 4.10s! If I figure it out I will tell you how to do it!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 10th, 2007, 10:40 PM   #16
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
my cheap friend had our friend with a m3 just run along side him one night while a passenger in the M3 read off certain speeds while the passenger in the mustang logged the rpms, gear and speed. He taped it up on the dash for the longest time until he finally just had it comitted to memory.
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old July 10th, 2007, 11:43 PM   #17
ujslost's Avatar
my buddy bought a mustang once, that was done like that sorta, except they used a sharpie to write the MPH on the clear bezel over the gauges.
Old July 10th, 2007, 11:51 PM   #18
Proud American
lol I would never do anything like that! I am going to get this corrected! If you havent learnd by now, when it comes to the stang I am going to do it correctly only once! lol Thats why I went with the Speed Cal, I wanted it to be dead on!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 10th, 2007, 11:56 PM   #19
G.T. Rags's Avatar
Millenium Falcon
yeah, but in the mean time it'll keep u doing thr speed limit and u won't get tickets
Old July 11th, 2007, 12:01 AM   #20
Proud American
nope because my speedometer wont work at all now! lol and if it does move its not by much! I know I was doing at least 60 down one of the neigborhood streets today to see if it would move, but it didnt go passed 18 MPH! I am pissed!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Threads Similar to: HELP Speed Cal
6 speed c 4 460brevill Classic Mustangs 9 June 11th, 2007 07:10 AM
Top Speed on your GT? wormster00 2005 - 2010 25 March 29th, 2007 10:48 AM
I NEED SPEED 95blackbeauty 5.0 Mustangs 8 March 6th, 2007 11:52 AM
The NEED 4 Speed trueballerisme 2005 - 2010 6 February 27th, 2007 01:45 AM
the NEED for SPEED trueballerisme V6 Mustangs 14 February 26th, 2007 02:02 AM
