Piston difference
Are there any difference in the pistons from 96-98 v.s 99-04?? I thought I read somewhere that the pistons in 96-98's have a higher dome. Don't know if it was B.S. or not.
Parting out 2003 SVT Cobra Air/Fuel http://www.moddedmustangs.com/forums...003-cobra.html Engine http://www.moddedmustangs.com/forums...003-cobra.html |
Yeah there different thats why you get the compression increase
They should be about the same and the only reason you get a compression increase is because the combustion chambers are different in PI and Non PI heads
![]() EAGLE SCOUTS OR GTFO MyStangOpens (12:01:05 AM): honey nut for me |
No if they were the same than the 99 would have the higher compression also, the 98 and under has different pistons
The 96-98 have a smaller dish in the pistons than the 99-04's.
Mustangless atm 2006 2500 HD Diesel. Built allison trans and other goodies
#6 | |
Proud American
11cc on the NPI motors and 18cc on the PI motors if I remember correctly!
So the 99+ have a bigger dish with a smaller combustion chamber. And the 98- have a smaller dish with a bigger chamber? Then how come I hear that a 98- with PI heads is more powerful than a 99+ (which already has PI heads)? I mean, wouldn't a bigger combustion chamber mean a bigger dish??
The pistons on the 96-98 have a smaller dish than the 99+, the heads on the 96-98 have larger combustion chambers to lower the compression ratio. When you install the 99+ heads on the small dished Npi pistons it raises the compression ratio over a full point to somewhere around 10.4:1.
Threads Similar to: Piston difference
| 347? about rod & piston combo | And then some | 5.0 Mustangs | 14 | October 5th, 2007 11:54 AM |
| Whats the best piston to have? | powersrj | 5.0 Mustangs | 3 | August 21st, 2007 10:50 PM |
| Piston sizes? | MySallyMI | 99-04 | 9 | May 22nd, 2007 07:10 PM |
| Piston Question | bigbadtalontsi | 5.0 Mustangs | 5 | January 18th, 2007 12:20 PM |
| PISTON ? | 89GTCONV | 5.0 Mustangs | 1 | June 14th, 2006 10:44 PM |
