Discussing PI swap?? in the 96-98 Forum. Yeah that's what I've heard. I can't believe it's taken me ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
Parting out 2003 SVT Cobra Air/Fuel http://www.moddedmustangs.com/forums...003-cobra.html Engine http://www.moddedmustangs.com/forums...003-cobra.html |
#22 |
All Throttle with a Bottle
12.91@105.29 @ 5800 FT
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
#23 | |
I would replace the lifters .Mine didnt tick either ,but if your gonna step up to a more aggressive cam ,its a good idea .they go for about $100-110. I replaced mine cuz of the cams I got. I would say that the followers are PROBABLY ok ,but if you got the money then replace them. An easy inspection will tell you. What cams do you want ? For being such a young guy,you sound like you've done your homework. Just so you know, I did no headwork and you see my numbers.
Fryrice has left the building. |
#24 |
https://www.hitechmotorsport.com/sto...ducts_id=43790 I will probably do the lifters right now at this point, and leave out the followers and my manley valves! but would you suggest new chains and tensiors?
#25 |
Its hard to tell until you get everything off .The tensioners may be holding fine now,but once you remove them they will no longer have any oil pressure. So after they are compressed so they can be reinstalled with the cams ,they may not spring the same way they did with the oil pressure. You can inspect the chains visually . They are pretty strong actually . Are you doing the work yourself ?
#26 |
#27 |
And Anglico thanks for the complement. But you see I have nobody around here with the knowlegde I have thats near my age so its kinda annoying to my parents. And then again I do nothing but think and breath and sleep about these cars!
#28 |
#29 |
#30 |
#31 |
#32 |
#33 | |
The factory bottom can handle moderate boost no problem as long as you don't constantly spin it through the roof everyday.
#34 |
#35 |
Someone posted a topic in here about NPI heads on a PI block so the C/R went WAY down...I think everyone was estimating 8-ish. I am actually going to explore that soon because I am eventually adding a turbo to the 'stang and if I can run a crazy amount of boost and still keep the car drivable that'd be sweet. But besides that, I personally WOULD add a turbo to my car after the PI swap. Low boost plus preiously great N/A HP still equals more HP and alot of fun.
#36 |
#37 |
#38 |
#39 | |
#40 |
Threads Similar to: PI swap??
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 07:48 PM |
| 3.8 swap to 5.0 | goldhorse | V6 Mustangs | 1 | August 10th, 2007 01:57 AM |
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 32 | April 8th, 2007 08:15 PM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 6 | January 6th, 2007 03:37 AM |
| 351 Swap | Cskit1500 | 5.0 Mustangs | 6 | November 16th, 2006 08:40 PM |
