Look Ma! My First Post!
patriot stage 3 heads for 97 4.6L?????
im thinking about buying patriot stage 3 heads for my 97 4.6L is it a good idea or no???
Proud American
I says stay away from patriot, but they will work. A couple of people here are using the stage threes on there 99-04s and love them, but they had problems with valves. I suggest a set of livernois heads or VT heads if you would like to get a set of boxed heads. Although is you go with something like that the stage 2s will be compareable. ask as many questions you need!
Threads Similar to: patriot stage 3 heads for 97 4.6L?????
| Patriot Stage 2 heads cams | Smoothgrandmama | 99-04 | 21 | October 29th, 2007 08:52 PM |
| Patriot Cylinder Heads.....???? | jwarnick | 96-98 | 2 | July 1st, 2007 12:08 AM |
| Patriot Performance Heads | CantDrv55 | 99-04 | 2 | March 18th, 2007 12:51 AM |
| Patriot stage 3 heads. | MySallyMI | 99-04 | 9 | February 19th, 2007 12:08 PM |
