to stroke or not to stroke
Alright so my motor is giving me enough trouble now that i think i am going to tare back into it but if i do that i am going to do it right first off i will deffinetly change pistons so I am not running 10.2 compression i want to get down to 9.1 then i will deffinetly port and polish my heads but i am debating on stroking it because i think i will run a blower with the compression i am going to have but i really want more cubic inches what you all think
RLY SRS
Im a big fan of the 331...It does not have the oiling prblems like the 347 does...
![]() iTrader: 2 reviews
I say go with a power adder, lower the compression... Chris I am also a big fan of the 331 but he is working with the 4.6
Silver 04 Cobra... with a Whipple
YEah, 331/347 not applicable for this car. Unless we dont know he has a 302. So guessing you have a 4.6. I say stroke it. AND forced induction. If you have the money, build it right. Be happy with it.
What are you running now? Im guessing PI swap if youre runing such high compression.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
yep you guessed it p.i. head swap and more with a new motor with only 2,000 miles on it but every noise i keep fixing a new one arrives well i think stroking it would be sweet i have seen a 4.6l cobra motor that is stroked to a 320 somthing i wish i could stroke that far it seems like i can only go up to a 302
Yeah, PI swap does suck because of the high compression. Most people now go with a PI motor. And then boost it. I know people who stroke and usually come out with 5.1 liters. Why are you having so many problems with a PI swap ??? What kinda noises are comming out of it?
RLY SRS
OOpps I guess that is what I get for multi-tasking; I glanced at his sig and thought it said 95...
I had 331 on the brain becuase I currently working on a build for a friend... With the 4.6 I have heard great things about people stroking to a 302...Then go forced induction... |
stroke that bitch. the people who are getting the 320 are also doing a big bore but you hae to have an aluminum block to do that big of a bore on it.
#9 | |
boy if i do this i think i will keep it N/A for a while i don't think my tans could handle that kid of power with a blower
Yeah , the trans are junk. Im suprised i havent gotten syncro noise yet, i beat the crap out of my trans. Keep it N/A for a while and get used to the power and you might find you wouldnt even need any kinda F/I for a while. Depends on youre need for power.
my need of power is almost endless but yeah i will keep in n/a untill wither i get a t56 or some trans to handle the power i still got my chevelle to worry about
#13 | |
RLY SRS
What have you "heard" bad about a t56 in a 2v?
#15 | |
RLY SRS
Also a few guys running KB's have had some problems with the tranny not performing that well... Mainly I guess it is all preference...I love the TKO600 and the T56 I am sure is a great tranny but for my money I would go for the TKO600... |
MM's nicest mod, :)
well i am the guy to talk to about stroking the motor, why cause i have a 302 stroker. Well if you are going to go forced induction then i say go for it cause after that you will get that mid range tq that will help. If staying N/A then i say don't cause you will loose a little hp but gain tq. I have about 30 more tq than most n/a cars but not as much hp. The stroker needs alot of air to make power. i plan on going twin turbos so with the stroker i will make alot more power than a stock stroke motor.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
Chris youre saying a T56 which is in the Cobra has problems with a 2v's power!! Of course a TKO is better than a factory tremec.
White.... thanks for posting the info. I didnt relalize that you dont make much more power from a stroker. But then again, when you think about the motor already having a nice stroke to it, it tends to make sence.
#18 | |
RLY SRS
I have just had a few friends have problems with the 3rd and 4th for some reason...But given this could all be in the installment and it is a high possibility that it does not even involve the tranny... Now given the 6th gear is great for someone who wants gain alittle bit more drive ability with the 6th gear... INFO You can go to that site and see some of the problems the T56 can have...Now given that all trannys can be bad but I am not a fan of the T56...For the money you cant beat a TKO600... But Like I said that is my personal opinion...So take it for what its worth... It also depends on what your plans for the car contain... |
MM's nicest mod, :)
If someone was gonna drive their car everyday actually a T-56 would be better for gas milage and comfort of shifting, plus it will hold lots of power. The TKO-600 is a very strong tranny but its very notchy and a pain in the ass to shift. From what i hear its one of the worst shifting tranny's you can get, save some money and get a g-force T-5 which is the best shifting tranny i think you can get.
^^^ Agree'd. The tko500 is notchy as a bastard as well and makes alot of noise.
Threads Similar to: to stroke or not to stroke
| 2v to 4v conversion and a 281 to 302 stroke.. | MustangDrew212 | Modular Mustangs | 3 | August 20th, 2007 10:37 AM |
| Stroke it baby..... | Ole Yeller | V6 Mustangs | 20 | July 7th, 2007 07:56 AM |
| Stroke...huh? | marcfiebka | 99-04 | 2 | April 27th, 2007 03:38 AM |
| Stroke 5.0 | 06dkkiser | Modular Mustangs | 12 | November 13th, 2006 12:54 AM |
| To stroke or not to stroke | Vamp89 | 5.0 Mustangs | 4 | May 9th, 2006 01:19 AM |
