#21 |
Ok, say i do build this by myself. How much am i probably looking at spending to build just the shortblock? New block and everything just minus heads and cams. Just a ballpark figure would be nice.
#22 |
a assembled short block with a stroker kit is about $4500 give or take, the kits usually run around $2000 or so and a brand new stock Iron block is about $250
#23 |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
You could build a killer shortblock for $2500. Some of these engine companies are making a killing on their shortblocks, or atleast that's what it seems like to me.
#24 |
Proud American
Yeah they make a killing because not many dont know how or dont want to build an engine. I just wish I had 2500 extra bucks after I get all my PI swap parts done, so I cam make a killer bottom end run high compression and then a nice nitrous set up, but I cant!
#25 |
damn, thats not as bad as i thought itd be. I may be able to start earlier than i was thinkin.
#26 |
i was just thinkin, if you found a good deal on a short block out of a 96-98 cobra, could you put a PI swap on it and it all bolt up and work fine or would there be problems. I know that it would be smarter to get the complete top end to go with it, but if the only thing that is available is the short block, will it work???
#27 | |
MM's Mad Scientist
Slow Fella
#28 |
Proud American
Wait a second, you say the teskid block is weaker? What? are you drunk?
It will work and personally I really like the idea of doing it that way. Arne the pistons almost flat tops in the 96-98 cobra 4v?
#29 |
so you think that having a 96-98 cobra short block with PI heads and Intake will work and be a good combo? i was just sittin here tryin to think of a way to build a good small block. I already have PI heads and intake ready to install, I just dont wana have to get rid of them.
#30 | |
MM's Mad Scientist
Slow Fella
#31 |
Proud American
Well AC then am I confusing the teskid block being the best aluminum block you can get? I completely agree with the internals being weak and not worth it, but the weight savings up front IMO is worth it. That will drop 68 pounds or more off of the front end.
#32 |
MM's Mad Scientist
Slow Fella
You are correct that the Teksid is the best aluminum block. Also, if saving weight is the goal, that block would work. However, I was not aware that we were discussing weight saving techniques- I am only talking about what is strongest without regards to anything else.
#33 |
Proud American
Okay my mistake then!
#34 | |
03 gt vert
lights cant time it
NX EFI plate 250 jetcustom tune Eibach Pro-Kit Magnaflow cat back high flow cats, 3:55s, ported and polished heads, comp cams, forged pistons/ rods Curently building up 03 mach block w stage 3 port job. look for twins and more n2o |
#35 | |
#36 |
Proud American
Explorer Mach 1 blocks are WAP blocks correect? I have been keeping my eye out for ether a teskid or a WAP. Both will work fine right?
#37 |
1997 Mustang GT
Faster than an s4
I wouldn't worry too much about the block choice. That kit you are looking at will probably fail before the block will. Most of those kits are only good to 800hp or so. What are in the 03-04 Cobras? They are good to over 1100hp. I know they are manley rods and I think Probe pistons. But I don't know if they are H or I rods, if they are the better I rods or what?
Threads Similar to: Rotating Assembly?
| Install price for rotating assembly | Saleenwolf720 | 99-04 | 2 | October 8th, 2007 04:21 PM |
| Rotating Assembly | J Mac0123 | 99-04 | 13 | October 3rd, 2007 01:07 PM |
| Rotating Assembly on an 03' GT | hubba076 | 99-04 | 1 | May 16th, 2007 02:34 AM |
