1998 Mustang GT
Recalibrating a speedometer with new gears
After installing my new 410 gears I have found that I need to recalibrate my speedometer. Can you suggest a good tuner to do this at a cheap price. I have looked at the Diablo for $400. Is this a good tuner? Is the tuner fairly easy to use? I am not very car mechanical. I took the car to have the speedometer recalibrated but was told that their machine could not do it and I needed to get a tuner.
48.47@ 12.58
you need to buy a speedo gear..
they are like 10 dollars if that. as for getting a tuner.. the Xcal and the snipers are both great tuners
Proud American
Tuner wont do change the speedo on our cars you etheir have to get the Speed cal or a gear!
1998 Mustang GT
Is the speedo gear easy to install? If I get a Speed cal will I still need a speedo gear?
48.47@ 12.58
yes a speedo gear is easy to install.
and no you won't need a seedcal if you the get gear and visa versa
1998 Mustang GT
In your opninon what is better the gear or tuner? I can use the Diablo tuner for other changes as well, correct? Money is not a real issue.
48.47@ 12.58
a gear is just a gear.. i really don't have an opinion on them because my car doesn't need one.
as far as a tuner goes both the SCT and the Sniper are great tuners. I just prefer the SCt myself.
Proud American
Again! A tuner will not correct a speedometer on the 96-98s! I have the speed cal and I think once I get to play with it more, I will have a dead on speedometer!
www.steeda.com carries any gear you need for your speedo. I paid $25 for mine after shipping. 99% of them are $10, but the 4.10 one is $15. UPS loves dragging you throw a Honda scrapyard, so they charge like $8 to ship the part.
1998 Mustang GT
Need to hit the track
how do the speedcal and speedo gear work? where does the speedo gear go and is the speedcal some sort of computer or what?
48.47@ 12.58
rando.. you pretty much got it right.
the speedo gear goes in your transmission. and the speedcal is electric.
Proud American
speed cal is like a computer that you put in between the vss and the speedometer!
The speedo gear is easily changed when you take the one bolt out that holds the VSS on and just swap it!
I put 410's in my car and bought the gear and my speedometer is still like ten off so that didnt even work I would go with the speedcal.
Proud American
Thats the exact reason I went the speedcal route
matt i didnt get to follow up on that speedcal post but u had gotten everything sorted right?
ps what was the problem?
88 LX automatic-non stroked 302 with iron heads 01 GT manual-h-pipe bullets dumped-125shot 97 GT automatic-SOLD |
Proud American
I basically got it fixed! Its still not 100 percent accurate, I just havent had time to mess with it!
What turn out to make it work was seting the dipswitches backward! lol 1s are down and 0 are up!
1998 Mustang GT
I decided to go with the speed cal. I bought a Diablo predator. I havent gotten it yet but hopefully it will help with the recal.
i thought tuners dont do that guys..and you might as well go ahead and by the gear to get it as close as possbile..
tuners do not fix our speedometers you have to have the speedcal box like matt bought the gear will still have you 10 to the high side which will add those miles up faster.
so you have to buy both..
Threads Similar to: Recalibrating a speedometer with new gears
| Speedometer | akatagyourit | 2.3 Mustangs | 2 | September 15th, 2007 01:24 AM |
| Speedometer | cdesha | 96-98 | 6 | August 15th, 2007 01:11 AM |
| Speedometer | Arhilion | 96-98 | 8 | May 23rd, 2007 07:36 AM |
| Speedometer. Kmh to mph | Timmano | V6 Mustangs | 7 | May 3rd, 2007 11:38 PM |
| new gears = speedometer issues. | Gtwrestler | Modular Mustangs | 17 | December 29th, 2006 03:58 PM |
