Putting in cobra engine in Mustang GT
Old July 10th, 2006, 01:45 PM   #1
1998 Mustang GT
oannamarie is on a distinguished road
I have a 1998 Mustang GT. I am looking to put in a cobra engine. Can any one tell me if I will have to alter any other parts or can I just purchase the engine and install it will the original mustang components. I am also looking to put on a cold air intake. Do you have any other suggestions to increase performace to the engine?
Old July 10th, 2006, 01:51 PM   #2
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
Well its a big involved process for the swap, you will need the computer and wiring harness, reconfig your keys, exhaust. And also a cold air will not do much for ya, the most any cold air will give you is between 5-10 hp if you are lucky. The best bang for buck would be a full exhaust and gears. With your 98 i would say go get a pi head conversion kit and some cams and exhaust and you would be making enough power to hang with most cars.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old July 10th, 2006, 01:53 PM   #3
1998 Mustang GT
Do you think it is worth putting a cobra engine in it. Are there things I can do to the existing engine to make it just as fast? I havent made any alterations to the car yet except I put flows on it with H pipes.
Old July 10th, 2006, 01:57 PM   #4
MM's nicest mod, :)
like i said above, keep the engine you have, buy some ported pi heads which are heads in 99-up, some stage 2 cams from say VT, and pi intake, mac headers, mac pro-chamber, and mac cat-back, and some 410 gears and a good tune and call it a day. That should give you over 300 at the wheels. Then when you get ballsy throw a 100 shot on it.
Old July 10th, 2006, 01:59 PM   #5
1998 Mustang GT
Thanks. Would you happen to know an estimated cost for all this? Is it cheaper?
Old July 10th, 2006, 02:03 PM   #6
MM's nicest mod, :)
Well it does cost a pretty penny, i think it might be cheaper than buying and getting a cobra motor installed. heads usually run anywhere from 1500-3000 depending on how heavily ported. Cams are only like 500 bucks, full exhaust from mac about 800 bucks, gears from mustangs tuning 135. The install cost is whats gonna be more, prob around 1000-1500 for labor for all that. oh yeah and for a tune around 500 bucks but if you can find a used chip and have it done for around 150. where are you located
Old July 10th, 2006, 02:15 PM   #7
1998 Mustang GT
I am in Maryland. What would be the best thing for me to do first since it is pricy? I am not mechanincally enclined. What kind of shop should I take it to? Im guessing I shouldnt take it where I would have oil changes etc.
Old July 10th, 2006, 02:22 PM   #8
MM's nicest mod, :)
well if you can bring your car to virginia beach, i don't know how far you are into maryland, there are a few shops and guy si can recommend for you that do a great job.
Old July 10th, 2006, 03:10 PM   #9
1998 Mustang GT
Actually I am about an hour from Virginia Beach. That wouldnt be to far.
Old July 10th, 2006, 03:17 PM   #10
1998 Mustang GT
Would you happen to know any places that do inside work as well like, apholstery?
Old July 10th, 2006, 05:10 PM   #11
MM's nicest mod, :)
No i dont' know anyone who does interior work, but if you want to give 9sec03cobra a pm he is the guy who put my motor in and did all the work on wht00gt's car also and is the best mechanic i know. Let me know if you pm him cause he doesn't come on here too much and i can give him a call and let him know.
Threads Similar to: Putting in cobra engine in Mustang GT
EVER HEAR OF PUTTING A 6.8 V-10 IN A MUSTANG boliver Modular Mustangs 21 March 9th, 2007 12:28 AM
Putting in a new engine addict V6 Mustangs 13 February 7th, 2007 02:35 PM
95 Cobra Gearbox / Transmission (Manual) Putting Oil Where? 5lcobra 5.0 Mustangs 1 October 26th, 2006 12:09 PM
Putting 97 cobra motor in 97 gt. bbrewer03 96-98 2 August 24th, 2006 01:35 AM
