Discussing S.O.S in the 96-98 Forum. my 96 gt stalls when i drive it for about 2.5 hrs in 90degree ...
Old August 2nd, 2007, 10:02 PM   #1
1996 mustang gt
S.O.S
my 96 gt stalls when i drive it for about 2.5 hrs in 90degree weather, sounds like fuel starvation but i replaced the fuel pump yesturday i also replaced the air iddler sensor but it still does it p.s there is no check engine light. thanks
Old August 2nd, 2007, 10:05 PM   #2
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
check your fan
Old August 2nd, 2007, 10:13 PM   #3
1996 mustang gt
the cooling fan works
sold the stang
Old August 2nd, 2007, 10:13 PM   #4
HMUSN's Avatar
19.83 @ 12mph
is it overheating at all?
Old August 2nd, 2007, 10:16 PM   #5
1996 mustang gt
no but after it sits for a while it drives again
sold the stang
Old August 2nd, 2007, 10:18 PM   #6
HMUSN's Avatar
19.83 @ 12mph
hmm... it really sounds like an overheating issue to me..
does it ever do it while sitting in traffic ?
are you positive that your gauge works?
Old August 2nd, 2007, 10:21 PM   #7
1996 mustang gt
yea it did that while in roushour traffic. i tried flooring it but sounded like it wasnt getting any fuell
sold the stang
Old August 2nd, 2007, 10:23 PM   #8
HMUSN's Avatar
19.83 @ 12mph
still on your stock injectors?
run a bottle of cleaner and see if it helps.
Old August 2nd, 2007, 10:27 PM   #9
1996 mustang gt
on my last tune up 15 days ago i used a 44k additive
sold the stang
Old August 2nd, 2007, 10:30 PM   #10
HMUSN's Avatar
19.83 @ 12mph
it has to be an over heating issue then.
fuel is fuel.. it doesn't matter what the ambient temp. is... if there is something wrong it will happen at all temps..
I am going to have to say overheating issue.
check your radiator for leaks your fan.. your fan speed.. your thermostat ,water pump ect...
Old August 2nd, 2007, 10:35 PM   #11
1996 mustang gt
if it were to overheat there would be antifreeze smell or would there
sold the stang
Old August 2nd, 2007, 10:38 PM   #12
HMUSN's Avatar
19.83 @ 12mph
depends on why it's overheating.
Old August 2nd, 2007, 10:43 PM   #13
1996 mustang gt
the fluids are ok and dont see any leeks but will flush my radiator and replace my thermostat see if it helps.
sold the stang
Old August 3rd, 2007, 03:10 AM   #14
The Great Unknown
Dennis-96GT's Avatar
11h47m32s
actually take the thermostat and wave a lighter under it and see if it pops that should tell you if its bad also sidenote remove the honeycomb grill while your at it if you havent already that will help reduce the heat alot
MEMBERS AGAINST STREET RACING
Old August 3rd, 2007, 07:57 AM   #15
Sounds like a bad thermo...
Old August 3rd, 2007, 01:30 PM   #16
96Snaker's Avatar
ex-1996 Cobra owner
better way is to drop the thermo into a pot of boiling water - to check to see if it is still in good operation.
The Cobra might be gone... but the blue blood still runneth thru my veins.
Snaker's Music
Snaker's Myspace
I'm extremely bendy
Old August 3rd, 2007, 02:24 PM   #17
The Great Unknown
11h47m32s
or that works too im just too lazy to boild a pot of water and all that so i just grab the bic lol
Old August 3rd, 2007, 05:19 PM   #18
If your cars not running hot and not leaking any antifreeze I would say the cooling system is fine no need to replace the thermostat wouldnt make it two hours of driving it that was not opening, it sounds like something electrical getting hot and breaking down.
