Crank Balancer Options 1998 GT - Forums at Modded Mustangs
post #1 of 10 Old April 16th, 2013, 09:48 PM Thread Starter
Layin low, sippin' slow..
Tequilla's Avatar
A while back my crank balancer separated so I replaced it with one from Auto Zone. Now I'm leaking a little from the seal so I need to pull it apart and replace the seal. Since I need to pull it apart I was thinking about upgrading the balancer. I checked Summit Racing and they have a few that are reasonably priced but I noticed they have different diameters available. I didn't measure mine but they offer 6.610" and 6.870" diameters. I assume the bigger diameter will slow the accessories down just a little? I have a '98 GT with 4:10 gears, a Bama tune, exhaust and a C.A.I and my only future mods will be a P.I. head swap. I assume with only these mods a stock type balancer would be fine but I wondered if there were any opinions out there if it's worth changing it or not. I did do a search but didn't find what I was looking for......... Thanks!
Layin low......sipping slow
Tequilla is offline
post #2 of 10 Old April 16th, 2013, 10:00 PM
Well if your gonna do the pulley do the march hydroboost crank pulley part # 1158
4vGts is offline
post #3 of 10 Old April 17th, 2013, 05:48 AM
xandraxal's Avatar
You could opt for the Steeda underdrive pulley set
xandraxal is offline
post #4 of 10 Old April 17th, 2013, 02:15 PM
a.k.a. Racecougar
Tang Stang's Avatar
A smaller diameter dampener will slow (underdrive) the accessories. A larger diameter dampener would speed up (overdrive) the accessories. The stock diameter should be 6.75". Typical underdrive dampeners for these engines are right around 5".
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Tang Stang is offline
post #5 of 10 Old April 17th, 2013, 08:39 PM Thread Starter
Tequilla's Avatar
I found the Marc #1158 at Summit Racing for $124.... Very reasonable. They don't list the diameter...... Is it stock, smaller or larger?
Tequilla is offline
post #6 of 10 Old April 18th, 2013, 08:40 AM
a.k.a. Racecougar
Tang Stang's Avatar
IIRC, the March #1158 is a 5" diameter dampener.
post #7 of 10 Old April 18th, 2013, 09:41 AM
Hooo Ha Ha
sharkbait's Avatar
iTrader: 10 reviews
For the money a balancer would cost your going to get better performance by placing that money elsewhere in the car.
853rwhp @ 23psi
75mm Turbo 5.4 swap E85
#turbo2v
10.11 @ 138mph STOCK LONGBLOCK
9.11 @ 149mph - New Longblock /w Powerglide
www.JPCracing.com 410-729-0005 ext. 11
PM me if you need any parts or advice!
sharkbait is offline
post #8 of 10 Old April 18th, 2013, 10:26 PM Thread Starter
Tequilla's Avatar
Will a 5" dampener use the stock belt or do you need a smaller one?
Would a Trick Flow Plenum be worth more power than the dampener? They are close to the same price........
Tequilla is offline
post #9 of 10 Old April 19th, 2013, 08:30 AM
a.k.a. Racecougar
Tang Stang's Avatar
You'll need a shorter belt.
post #10 of 10 Old April 22nd, 2013, 02:38 PM
Wiser by the Minute
aluv4speed's Avatar
If you plan on going FI anytime soon as in a Centri blower or twin screw then don't get an underdrive pulley!
Save yourself the time. I would actually get a bigger one if I was going FI like a 7.5
" Drive Fast - Take Risks "
On3 2nd gen kit, 78/68 Benita, E85, - 628/654 16psi | 677/695 18psi {Just swapped in the Edelbrock, 6061 plenum, 75mm tb, & 4" intercooler} Need new tune.
aluv4speed is offline
Human Verification
