Discussing Changing Tranny Fluid??? Where are the plugs??? in the 96-98 Forum. I have a 96' COBRA w/ the T45 Warner... I'm getting a good bit ...
Old August 6th, 2007, 03:21 PM   #1
I have a 96' COBRA w/ the T45 Warner... I'm getting a good bit of heat from the center consol.. so I'm thinkin that my tranny fluid may be low. It wouldn't hurt to change anyway.
SO... Where are the plugs? Thanks guys
http://a598.ac-images.myspacecdn.com...2851335ded.jpg
96' "Slowbra"
B&M Shifter
JLT RAI
No Cats
Flowmasters
Wheel Spacers
KYB struts
Eibach Springs
BF Goodwrich G-Force in 4 corners.
Old August 6th, 2007, 09:40 PM   #2
68 dlxcoupe's Avatar
2004 Mach 1
13.30 @ 104.47
Look on the passenger side of the trans. It has two plugs one above the other. The bottom is the drain plug and top is the fill. It goes a little easier if you take the fill one out first then the drain one out. And its right on the side of the trans you cant miss them.
http://www.moonshine-media.net/68dlx2.jpg
EAGLE SCOUTS OR GTFO
MyStangOpens (12:01:05 AM): honey nut for me
Old August 6th, 2007, 11:23 PM   #3
bbrewer03's Avatar
So the manual transmissions do have fluid in them? I have been told so many things about this topic I dont know what to believe. When I first purchased my 97 GT I did all the normal maintenance things. One of the things I wanted to do was this. I was told that manual trans did not need fluid. That it had more of a grease type stuff in it and it never has to be changed. I wanted to put the purple stuff in it. So am I reading this right? You can changed your manual trans fluid.
1997 GT
Cobra R Hood, Cobra Front bumper, MSD plug wires, Bosch +4 plugs, Tailights, Projector headlights, 18x9 chrome bullet wheels in front and 18x10s in back, Tunable Induction Cold air intake, flowmaster mufflers with chrome 18"x 4" wide tips.
Old August 6th, 2007, 11:24 PM   #4
All Throttle with a Bottle
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
yeah but you put ATF. And it denfinaly needs to be changed sometimes!
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Threads Similar to: Changing Tranny Fluid??? Where are the plugs???
changing trans fluid with royal purple 01dutchGT 99-04 4 October 23rd, 2007 12:55 AM
Just got a 2000 GT, advice on changing Plugs and Springs Philipk2003 99-04 6 June 25th, 2007 11:56 PM
Changing + flushing transmission fluid (do it yourself?) lolfast Drivetrain 2 March 16th, 2007 01:42 AM
need an easy way of changing my plugs in my 2000 (v-6) timwade Engine 1 February 25th, 2007 06:01 PM
Fluid Flush/Changing DSEZ Engine 1 January 31st, 2007 06:05 PM
