Water temp sensor relocate?
So where have all you guys that have done the PI swap put the extra water temp sensor. I am putting an aftermarket intake manifold on there and there is only one hole for the two sensors. I have heard that people have put a t fitting on that hole and used both sensors, or have just used one sensor but rewired the wiring harness. Any help? That is all I have left to do with the swap and then I will be driving again.
Chris
96 GT, CAI, 75mm TB, PP Plenum, typhoon intake manifold, BBK shorties, flowmaster catack, UPR x pipe, FRPP 9mm race wires, complete PI swap |
Proud American
I say dont do the T-fitting, but you can put the sensor in the block somewhere and you will get more acurate readings! I will look for the post about it here
all after market intakes should have a spot left where the second 1 can be placed...it will be in the same location as the origanal but itll need to be drilled and tapped...
Threads Similar to: Water temp sensor relocate?
| Air temp sensor relocation | Saleen0101 | Modular Mustangs | 2 | September 22nd, 2007 07:03 PM |
| Water Temp & Oil Pressure | gotboost562 | 5.0 Mustangs | 1 | September 4th, 2007 10:50 PM |
| water temp | coreyfitz | 94-95 | 1 | May 2nd, 2007 12:18 PM |
| water temp sending unit | Superfly76 | 99-04 | 23 | April 30th, 2007 12:01 PM |
| no temp sensor how to connect one? | roscoe | 5.0 Mustangs | 2 | February 14th, 2007 09:04 PM |
