Timing help please
Old August 11th, 2007, 08:05 PM   #1
ckjacobus is on a distinguished road
Timing help please
When I reset the timimg and got the chains reinstalled. I am turning the engine over manually with a wrench and the chain sometimes gets a little loose on the top side from stroke to stroke. It does it on both sides. Is this normal? I don't remember if it did it before I took it off.
Thanks,
Chris
96 GT, CAI, 75mm TB, PP Plenum, typhoon intake manifold, BBK shorties, flowmaster catack, UPR x pipe, FRPP 9mm race wires, complete PI swap
Old August 13th, 2007, 06:55 AM   #2
Fryrice's Avatar
Fryrice will become famous soon enoughFryrice will become famous soon enough
How many miles on the car ? The chains should have been really tight before you took them off.
If you have the tensioners and everything installed properly ,but you still have some slack ,your probably ok. Theres usually slack in the chains since theres no oil pressure in the tensioners,
When you prime the oil system before you start the car for the first time,they should tighten up some more like mine did.
Fryrice has left the building.
Threads Similar to: Timing help please
need timing help bad!!!!!!!!!!!!!!!!!!!!!! sloppyjosey 5.0 Mustangs 18 October 23rd, 2007 06:34 PM
More Re-timing help 97redgt Modular Mustangs 1 September 9th, 2007 09:24 PM
timing punkafi888 V6 Mustangs 13 March 29th, 2007 02:01 AM
need help on my timing????? tag team 5.0 Mustangs 3 March 26th, 2007 01:04 AM
Timing weems 5.0 Mustangs 10 October 14th, 2006 12:26 AM
