Discussing ticking problem please help!!!!! in the 96-98 Forum. Well I finished the PI swap today and I have an oil leak at the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Well I finished the PI swap today and I have an oil leak at the driver's side valve cover. That is actually an easy fix, but I also have a ticking noise that I can't isolate yet because I only ran my car for about 10 seconds because of the oil leak. Could it just be that since I was leaking oil pretty badly that the lifters and all that stuff haven't built up the oil pressure yet to work quietly? I am hoping that is just that or maybe the tensioners for the timing chains since they are oil pressure dependent as well. I am fairly sure that it is not PTV problems because I cranked the motor with the coils unplugged 15 or 20 times before I fired it up and they didn't hit the pistons at all then. Does anyone have any ideas, I need to get my car back up again.
96 GT, CAI, 75mm TB, PP Plenum, typhoon intake manifold, BBK shorties, flowmaster catack, UPR x pipe, FRPP 9mm race wires, complete PI swap |
All Throttle with a Bottle
12.91@105.29 @ 5800 FT
get that valve cover leak fixed! See if it stops when you start it back up and get oil in there. Also what cams did you go with? And also did you replace the lifters? If you didnt I would say its the lifters ticking especally if you went with any aftermarket cam! Anyway let me know!
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals. I support the MM Staff
I left the stock PI cam in there. I couldn't come up with the money to get any aftermarket cams yet. I eventually will.
did you reuse your old followers? Reason being, the PI cams have a higher lift and that is what might be causing the ticking!!
I'm guessing it is the lash adjusters/lifters needing to finish pumping up.
Threads Similar to: ticking problem please help!!!!!
| 00 gt ticking | smokinv6 | 99-04 | 23 | August 27th, 2007 11:47 PM |
| TICKING??? | 04gt | 99-04 | 19 | June 28th, 2007 12:07 AM |
| ticking in valvetrain..... | the black widow | 5.0 Mustangs | 4 | May 8th, 2007 05:39 AM |
| ticking noise | kreil45 | 5.0 Mustangs | 2 | April 23rd, 2007 03:11 PM |
| Ticking? | mustang kid 1989 | V6 Mustangs | 14 | November 11th, 2006 10:03 PM |
