94 cobra
big problem need help
my car failed the mass inspection for emissions. the guy at the shop where i got my sticker said i need all the O2 sensors and the egr valve because it had 8 codes. i researched the codes and this is true. but i don't have the money to do all this right now cause im going back to school soon and cant work anymore but i need to get a sticker. here is my plan i was wondering what you guys thought and if it will work. i am going to clean and replace the egr myself and then i have a buddy who does custom exhausts so i was going to have him put an O/R x pipe or something with no cats and new mufflers and then install mils without changing the sensors so that my CEL wont throw anymore codes and will hopefully pass emissions (since there are no codes). i think this is the cheapest way to go and much better then just replacing the sensors for all that money and no hp gains like the new exhaust will. please help me and any other ideas will be aprieciated.
One Man Wolf Pack
do they measure the exhaust itself, as in what comes out of the tailpipe?
![]() ΜΟΛΩΝ ΛΑΒΕ
if they measure exhaust out the tailpipe... nes says you will still fail emissions.
silver 98gt, blown- sold laser red 98gt, stock- gave away stormy blue 09 mazda3-traded 09 subaru wrx- soon to be 12 sec. daily driver ![]() 1988 gt- toy
#4 | |
im can remember u asking about this before or some1 else, but if it is u and they only check for the codes, the MIL will work, but if they measure form ur tailpipes it iwll do nothing for u except take ur CEL off
lol hows the car man?
88 LX automatic-non stroked 302 with iron heads 01 GT manual-h-pipe bullets dumped-125shot 97 GT automatic-SOLD |
doing all that will cost more than just getting new o2s
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
#6 | |
Smelly Fists, Socking Cocks
Millenium Falcon
Proud American
mine passes the sniffer test, but i dont need one either!
94 cobra
they dont hook anything up to the tail pipe just to the computer and it would cost about the same because i know the exhaust guy and he hooks me up and i want to put an exhaust on anyway so i figure it will save me money
cobra R hood (has a vin#) bassani catback flows welded in jegs O/R H-pipe Jlt CAI Mgw shifter 03 cobra rims 3.73's (on the way!!!) |
MM's Coffee Addict
Check with the local laws in your area. Some emission control stations in WA visually check for catalytic converters. As is the same when I lived in CA but not AZ. Emissions laws change yearly, and in different counties within states as well. One station may require cats, whereas one in a different county may only check the readings at the tailpipe opening.
![]() Vortech V2, intercooled @ 10psi. Maximum Motorsports supsension goodie bag car less roll cage. Built '04 IRS. Hodge-podge of Roush/Stalker panels. |
yo, i dont know where your geting a sticker but in MA you NEED cats, a shop is suposed to fail u if you dont have them reguardless of the sniff test, i live right in NH on the line. i picked up my camaro fairly cheap from ma, and same with my stang... unless the shop is easy going on inspection or u know the guy... and OR pipe wont pass...
96 GT , cams,intake manifold,CAI,Exhaust,Full Hotchkis suspension, and many more |
94 cobra
yeah i know the guy if its not throwing any codes its fine same with most shops
where are u form in MA
94 cobra
canton
Threads Similar to: big problem need help
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 01:03 PM |
| Has your car ever had a problem? | JASonic | The Clubhouse | 17 | September 19th, 2007 06:19 PM |
| RIM Problem and Help | trueballerisme | 2005 - 2010 | 70 | August 21st, 2007 09:55 PM |
| t-5 problem | notsoslow50 | 5.0 Mustangs | 7 | August 17th, 2007 08:16 PM |
| TPS Problem? | 88Horseman | 5.0 Mustangs | 11 | November 14th, 2006 12:46 AM |
