5.4L Head swap???
Interesting site I have found here... Trying to figure out if I just wasted a bunch of money on E-Bay... Found a set of heads off an 02' Lighting (5.4L Supercharged) hoping they will work on my 97 GT (bone stock). Any Tech experts out there whom may know the answer, and also if I should be swapping the Cams out when I make the switch from Supercharged to not? Lastly, this swap all started with that damn plastic intake cracking, (why not get some PI heads at the same time), so what Intake would I use with these Heads, assuming they will work at all? I was kinda assuming if the heads would work, then the intake for a GT should also work.
Ford had a good idea when they decided to use a MOD motor platform.... 4.6/5.4 are the same
Aside from bore/stroke... they are interchangable. So go ahead and put them bad boys on youre car. Not EXACTLY sure on the s/c specs on the cams, but i would just leave them in there.... unless you have a Stage cam you want to put in there.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
All of the cams are the same also.
MM's nicest mod, :)
uh i didn't think the heads are interchangable but i guess i was wrong. but you can use the pi intake with an adapter that just came out from a company i can't remember its name, its in the new 5.0 mag.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
White... what adapter. I have the 5.0 with the Shelby on it.... just checked and didnt see anything ?
how much are 5.4 heads going for? you think its worth it or is it better to just buy some aftermarket patriot heads or afr's or whatever?
12.04 at 115mph with a 1.9 60' |
i was readin my new 5.0 mag today and found these new conversion plates. they let you use the 4.6 intake on the 5.4 heads so you can out the 5.4 heads on. they are at www.reichardracing.com
#8 | |
RLY SRS
Threads Similar to: 5.4L Head swap???
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 01:57 AM |
| 4.6L PI Head Swap Kit | slvrbllt98GT | 96-98 | 5 | June 14th, 2007 04:29 PM |
| head swap | Mustang RacR94 | 99-04 | 9 | April 25th, 2007 06:27 PM |
| Cam and head swap I need help!!!!! | Kevin b | 5.0 Mustangs | 19 | January 3rd, 2007 01:30 AM |
| Head Swap | wikdsvt | 5.0 Mustangs | 5 | October 10th, 2006 07:19 PM |
