#21 | |
-BBK CAI, BASSANI CB + X, SCT 93 tune, 4.10s, Cobra brakes, Cobra R wrapped in nitto 555 tire. -College Football and studies take up the bulk of my time. |
#22 |
Proud American
I personally like my system! lol but then again I will not change anything on my car unless its for quicker ETs! lol
#23 | |
The Hammer
Millenium Falcon
these are the specs Size 12" Magnet 109 oz. Power Handling 600 watts RMS/1200 peak #v.coils/Impedance dual 4 ohm v.c Frequency Response 25 - 2500Hz Efficiency 86dB (1W/1M) Fs/Hz 27 Re 7.9 Qts 0.57 Vas/liter/ft3 91.65/3.23 Xmax 16mm Depth 8" powered byDirected Audio Amplifier D1200 Type Class D Mono Maximum Power 1200 Watts CEA Primary Power (power into 4 ohm, all channels driven, 14.4V supply 1% THD+N) 300W x 1 CEA S/N Ratio (referenced at 1 watt/4 ohm) 60dB CEA Additional Power (power into X ohm, all channels driven, 14.4V supply 1% THD+N) 600W x 1 @ 1 ohm Frequency Response 20 - 250Hz Damping Factor >50 Input Sensitivity 150mV to 7.5V Crossover Type Variable 12dB low-pass Bass EQ Yes 8dB Protection* T,S,D,R,O,L Dimensions - inches (W x H x L) W:10-3/4 x H:2-1/2 x L:12-5/8 Metric - mm W:273 x H:63.5 x L:320 my subwoofers were discontinued, they only make 15's and 10's now...unless u upgrade to the top of the line sub. The company that makes them is the same company that makes Polk audio, and orion. My friend had the same subs and had them stolen on him and went nuts trying to replace them. Wound up with jmacs i believe, which also came highly recommended....hates them though......wishes he could get his old ones |
#24 | ||
RLY SRS
#25 | |||
The Hammer
Millenium Falcon
#26 |
1998 Mustang GT
www.installdr.com, here is the website that can help you install aftermarket stereo with mach 460 system
Threads Similar to: mach 460
| mach 1's | 02MiNeRaLgRaYGT | 99-04 | 47 | September 28th, 2007 08:12 PM |
| Mach 1s again | shamntgmry | 99-04 | 2 | September 27th, 2007 05:00 PM |
| Mach 1 | FastBack71 | Modular Mustangs | 27 | March 1st, 2007 10:48 AM |
| 04 mach 1 | rchauvin | General Tech | 13 | February 18th, 2007 12:38 PM |
| Mach 1 Lip | Brianzeke007 | V6 Mustangs | 1 | December 29th, 2006 09:38 PM |
