Discussing PI Cam Tommorow HELP in the 96-98 Forum. I've read caspers write up, and one from stangnet. I have all the sockets, ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
PI Cam Tommorow HELPTake followers out ( i'll be using a flat head screw driver), undo cam girdles (slowly as to not break), unbolt cam gear ( watch to not drop gasket between cam and the gear, replace cam, replace followers, cam gear. I'm pretty sure i'm good to go i just want to make sure cause i haven't done any work like this before. Thanks in advance guys.
steeda tri-ax, pypes catback & o/r x, BBK shorties, K&N cai, Full PI Swap, pro-m 80mm maf, 75mm tb and c&l plenum, steeda ud's, screamin demon cp's and ford racing 9mm wires, fox 4cyl front springs 260rwhp 290rwtq |
Anyone?
13.023@103.46 @ 5800 FT
sounds good, are you taking the timing cover off? If not I have heard of keeping slack in the timing chains by tieing it to the ceiling to hold it up. And to get the cam gear off, you should be able to do that with a braker bar, but i am not for sure!
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Threads Similar to: PI Cam Tommorow HELP
| Starting it up tommorow | 89LX347 | 5.0 Mustangs | 56 | October 1st, 2007 12:51 AM |
| ordering tommorow *poll* | 232stang | The Clubhouse | 5 | August 2nd, 2007 10:52 PM |
| New drivehsaft gettin here tommorow!!! | RStrick0352 | 2005+ | 16 | June 7th, 2007 05:59 AM |
| Replacing O2 Sensors Tommorow Which Ones to Get? | Bigb2000GT | 99-04 | 9 | March 23rd, 2007 09:14 AM |
| Installs happening tommorow | flattusmaximus78 | 2005+ | 3 | February 15th, 2007 12:31 AM |
