wont start
I have a 96 Gt, and last night it wouldnt start, i thought maybe it was just flooded, but it wouldnt work this morning either, Its got juice, it'll start up and try to idle for a second, but then it just cuts right out...any ideas on what might be wrong?
Proud American
Is it getting spark?
Smelly Fists, Socking Cocks
Millenium Falcon
is ur fuel pump turning on........?
it would make a loud humming noise when u turn the key into the on position, right before it cranks. |
won't run
well obviously if it turns on there is a spark, i figured out that it was my key, the micro-chip got damaged from throwing the keys the other day...so now my problem is getting the theft system to fuck off...any ideas or am I SOL and have to get new keys?
Millenium Falcon
u can either rip out PATS or get new keys......but i dunno how u would go about that seeing that ur chip is damaged.....they might not be able to copy the code to burn it on a new key
it doesn't sound like your key.
it would not have started at all if it involved your pats system it's fuel related.
well the theft light is blinking...and it wouldnt just be by coincidence that the key broke at the same time...cause it worked great...i just shut it off..threw my key to a friend and he threw it back and it hit the pavement pretty hard. How would i take the PATS system out on my own?
if it is indeed your key.. you are going to spend a lot more taking out the pats system then you will on the $100.00 for a new key.
well, its going to cost me 180 for a key, and 85 to tow the car so they can reprogram it too...im just looking for something cheap to get it done for now.
the pats system is very complex man.
the cheaper route is to get the key... you will still need to tow your car to get it retuned if you took pats out.
Millenium Falcon
ur getting ripped off.......
unless there charging u more because they can't rip the burn off ur original key.... it should only cost 50 bux to take the program off ur key, and then 50 bux per key... |
well its 180 for 2 keys, plus towing of 85...but im worried now, if the fuel pump comes on...and the car starts...then shuts off..what else could be wrong?
I'm telling ya... it's not your pats.
it's fuel related. check your fuel filter, injectors..
Millenium Falcon
what kind of keys and/or alarm system.
do u just have keys or do ui have an alarm to or keyless entry? |
ok..how do i check them, can i do it myself?
I just have the 1996 GT model, its fully loaded with all the factory gimmics...i have a little thing with the key like with the panic/trunk/unlock and lock on it |
Millenium Falcon
is anything happening when u turn ur key........power turning on?
your gonna have to have a new key cut and have it reprogrammed and yes it is worth $100 if ya dont know how to do it your self.
I agree that its fuel related.
1986 Mustang GT t-top time piece! |
k this is exactly what happens...I turn the key to on, and the fuel pump powers up...it turns over and is running for no more than a second, then cuts out
Millenium Falcon
it's not PATS then.....
if it was ur chip ur car wouldn't start at all, u wouldn't get power to crap.... the same thing is goin on with my buddy's 98 right now. we think it's his fuel filter or the fuel pump relay. his filter turns on but barely and then shuts off. It does it speratically though, and he's to much of a douche to be on top of it unless its urgent |
well If thats the case then i dunno what to do, still have to tow it i guess right?
I might be able to take the filter off and clean it, if that is possible...and the fuel pump turns on everytime like it always used to..no difference at all |
Threads Similar to: wont start
| Wont Start | caintcatchmyGT | 96-98 | 3 | September 11th, 2007 12:02 AM |
| need help...car wont start | orlyr21 | V6 Mustangs | 8 | January 13th, 2007 09:17 PM |
| wont start?? | shadowgames81 | 5.0 Mustangs | 10 | January 7th, 2007 10:10 PM |
| 91-92 5.0 gt wont start | sturcotte3 | 5.0 Mustangs | 0 | January 1st, 2007 06:40 PM |
| Need Some Help - Car Wont Start | ANoXiA | 2005 - 2010 | 6 | December 23rd, 2006 07:07 PM |
