Tools needed for changing brake pads and rotors? - Forums at Modded Mustangs
post #1 of 5 Old September 20th, 2013, 01:09 AM Thread Starter
So the only think I would need is a socket wrench with the proper sockets. Does anyone know the exact measurements I need? I have a 96 GT. Everything is stock.
Also should I install SS lines while I am doing it? I plan on doing a brake swap in the future, should I do it then?
Brigade is offline
post #2 of 5 Old September 20th, 2013, 08:39 AM
nkausch's Avatar
The ss brake lines are nice. You'll also need a hex head but I forget what size. If I remember correctly you also need a 10mm and a 1/2 inch? I think?
Sent from AutoGuide.com App
94 GT Vert
<a href="http://www.moddedmustangs.com/forums/projects/277159-nkauschs-turbo-vert-pic-heavy.html"]http://www.moddedmustangs.com/forums/projects/277159-nkauschs-turbo-vert-pic-heavy.html">70mm Turbo Build</A>
nkausch is offline
post #3 of 5 Old September 20th, 2013, 09:58 AM
a.k.a. Racecougar
Tang Stang's Avatar
You'll also need a C-clamp when changing the front pads and the correct caliper tool for changing the rear pads.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Tang Stang is offline
post #4 of 5 Old September 22nd, 2013, 10:08 AM
Cqd24's Avatar
Should be a mix of 12 mm and 15 mm sockets (15 mm hold the bracket for the caliper). The front rotors you can use a C clamp to push the pistons back in, make sure to uncap your brake fluid reservoir. The rears you need the kit posted above, or napa/any auto store should also have a socket that can do it too. Rear caliper pistons need to be spun back in.
'03 GT, O/R X, LM1, SLP Longtubes, HP292s, 4.10s
'02 C5 Z51
Cqd24 is offline
post #5 of 5 Old September 30th, 2013, 11:16 AM
. This.
unscarred785 is offline
Human Verification
