Can anyone help me on how to fix these codes?
Old September 1st, 2007, 11:32 PM   #1
96cobraclone's Avatar
96cobraclone is on a distinguished road
Send a message via MSN to 96cobraclone
P1400 Differential Pressure Feedback Electronic Sensor circuit Low Voltage
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault.
ANY help is appriciated!
Old September 2nd, 2007, 12:01 PM   #2
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
the second one.....p1443....
do u fill up with ur car running......is ur gas cap on tight.
thats a frequent code mentioned on this site, u might want to use the search feature for it.
mine car threw that code 2x......both times i had let the gas get reall low.
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old September 2nd, 2007, 12:02 PM   #3
Proud American
MustangMatt96GT's Avatar
do u fill up with ur car running......is ur gas tank on tight.
Gas Cap
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old September 2nd, 2007, 12:04 PM   #4
The Hammer
G.T. Rags's Avatar
Millenium Falcon
Old September 6th, 2007, 10:01 PM   #5
jagstang96's Avatar
jagstang96 is on a distinguished road
well that codes is kinda of simple to fix here it is like the guys said it could be the gas cap if its not that then its going to be the evap solenoid or the sensor before it but more than likely it will be the evaporative solenoid and it is found on the vacumm line fo the back of the plenum follow the line towards the ac condenser u will c the sensor and keep follwing the line the solenoid will be next. good luck
Threads Similar to: Can anyone help me on how to fix these codes?
woo hoo more CEL codes mikethetigerrr V6 Mustangs 10 August 22nd, 2007 01:42 PM
Codes 8A_Honda 5.0 Mustangs 0 August 16th, 2007 08:06 PM
CEL came on. Codes JASonic The Clubhouse 2 July 27th, 2007 05:57 PM
Too many codes. Need help..... bad!!! 88Horseman 5.0 Mustangs 1 October 22nd, 2006 03:47 AM
Ran Codes 94, 44, And 33 hmotes 5.0 Mustangs 3 October 3rd, 2006 07:20 PM
