Discussing PI intake leak in the 96-98 Forum. I put my PI intake in a few weeks ago and it has been perfectly ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
PI intake leak
I put my PI intake in a few weeks ago and it has been perfectly fine ever since. Now, I have coolant leaking from the thermostat housing where it connects to the intake itself. It does have the aluminum crossover and seems to be leaking from where the aluminum housing seats onto the plastic manifold. Any ideas on how to fix this? Its not a major leak but you never know with these kind of things.
Who cares what your import looks like... They'll all be laughing at you at the finish line. |
Are you sure you put the o-ring back in it ?
Fryrice has left the building. |
Well its not leaking around the top of the housing. Its leaking at the bottom where the housing itself meets the manifold. Im positive I put the o-ring back in.
Yeah where it bolts down right and sits on the crossover?
Its almost like its leaking from the crossover. It's leaking where the metal crossover meets the plastic manifold. Not really the housing, more like the seal between the bottom of the housing and the top of the manifold. I tried taking a few pics but you can't really see it.
Do you have a black light ? Wipe everything down real good and try that.
Ive never done it,but the neon coolant should show up easily with that,and you may be able to spot the leak.
Damn I never thought about that. It will probably work. I saw a small bubble earlier on the back of the housing at the seam between the housing and manifold. I'm guessing thats where its coming from, but I'm not sure how to stop it. Any suggestions there?
If your talking about the rim of the t-stat housing where its flat to the crossover ,then its coming from the inside the housing. You might wanna pop that off and take a look at that o-ring and make sure its in there and in the right position.
Try the black light to. You can buy a bulb at Wal-mart and just put in a a hanging light like you would use in the garage or under the car. At night of course. They are both cheap.
Threads Similar to: PI intake leak
| leak ! | 96gtponyred | 96-98 | 39 | September 11th, 2007 05:04 PM |
| Leak | garydahl | Modular Mustangs | 6 | August 7th, 2007 04:06 PM |
| intake leak | noppe180 | 96-98 | 15 | April 28th, 2007 01:12 PM |
| Evaporative Emission System Leak Detected (very small leak) | Juggalo_X | V6 Mustangs | 11 | April 25th, 2007 05:46 PM |
| Oil Leak | Stangzilla | 5.0 Mustangs | 25 | November 6th, 2006 06:00 PM |
