Need help with Autometers blue wire to clutch switch
Old September 8th, 2007, 01:42 AM   #1
markush is on a distinguished road
I just installed an Autometer DPSS level 2 digital tack/shift light. on my 98GT. Everything’s good except if I want to use the launch feature at the same time as the shift light feature I need to connect the blue wire to my clutch....This is Autometers instructions...
"Blue Wire: Connect to positive terminal of Trans-Brake or Line Lock Solenoid. Alternatively, connect to the Brake Light Switch, Clutch Switch,
or a dedicated Remote Start Switch (normally open, momentary closed)."
The switch on my clutch only has power when the key is turned to START and not with the key in the RUN position. Am I missing something? Can anyone tell me How to wire this thing?
Threads Similar to: Need help with Autometers blue wire to clutch switch
Manual fan override switch; Which wire to splice? sorrowfulkiller Modular Mustangs 9 October 23rd, 2007 11:33 PM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 10:08 AM
Installing Zex window switch ! Tach wire help NEEDED calpat1985 99-04 0 May 8th, 2007 07:59 PM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 02:33 PM
Clutch start switch shadowgames81 5.0 Mustangs 6 January 7th, 2007 12:00 PM
