Cams...
Old September 8th, 2007, 07:29 PM   #1
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
Cams...
So my gears are in, i ordered the remaining parts for my intake swap, and am scheduled to do it next sunday, the 16th.
But that means i can start buying my next mod. Cams. I need to know what I'm going to need parts wise. Besides the cams themselves, what am i going to need for these to work properly in my NPI heads? I'm pretty much a novice in this field, so i might need a little help understanding the terms ur using.
As of right now, my future mods are as follows.......Accufab 70mm tb/plenum, underdrive pulleys, CAI, screamin demon coild n wires, and a tuner, haven't decided which one yet.
what cams would go good with these mods+PI intake and 4.10's?
what am i going to need parts wise to make everything work in NPI heads?
I've heard something about clearance issues with stage 2 set ups, can someone elabirate?
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old September 8th, 2007, 08:07 PM   #2
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
If you run a crower offset valve spring retainer you can run a .550" lift cam. You can order any grind cam with a lower lift, find a gring you like and have a custom lift grind made. Depending on where you want your power range will make or break the combo.
Old September 8th, 2007, 08:16 PM   #3
G.T. Rags's Avatar
Millenium Falcon
whats a croweroffset valve spring retainer and how does it work?
u basically told me i need these in order to run an afermarket cam, correct?
Old September 8th, 2007, 10:03 PM   #4
If you wish to run over a .540" lift cam. If you want you could always order a custom grind that will not require a offset retainer. Npi heads are limited to around .542 " lift before interference issues come into effect. You can have machine work done to accept the larger lift or run an offset retainer. The Npi heads like high lift so one or the other if you want to take advantage of what the npi head has to offer.
A offset retainer is used to create more room between itself and the valve seal allowing a higher lift cam to be used. Do you need them ? Only if you want to run an aftermarket cam with more than .540 lift.
Old September 8th, 2007, 10:22 PM   #5
G.T. Rags's Avatar
Millenium Falcon
where can i obtain an offset retainer?
i've been looking at COMP CAMS FORD 4.6/5.4 SOHC XE 270 CAMSHAFTS
do i need to match anything up specific with the cams and valve springs?
anyone have any recommendations on what i should use with these cams?
Old September 8th, 2007, 11:20 PM   #6
jersey98gt is on a distinguished road
Send a message via AIM to jersey98gt
all i know is they used that cam (XE270) in last months MM&FF and it made big power
-BBK CAI, BASSANI CB + X, SCT 93 tune, 4.10s, Cobra brakes, Cobra R wrapped in nitto 555 tire.
-College Football and studies take up the bulk of my time.
Old September 8th, 2007, 11:24 PM   #7
Proud American
MustangMatt96GT's Avatar
so did the typhoon too!
I would say go with a crower stage 2NPI ragtop, or u could contact comp and have them grind u a custom set!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old September 8th, 2007, 11:44 PM   #8
G.T. Rags's Avatar
Millenium Falcon
so i was looking at these after i saw ur suggestion matty
stage 2's
am i still going to need an offset retainer with these even though there emant for NPI?
and when they say it must be tuned...can i get away with a handheld or am i gonna need a dynotune? i don't wanna sped big bucks on custom tuning only to have to retune it.
Old September 8th, 2007, 11:46 PM   #9
Proud American
dyno for any after market cam
and well yes u will have to run a offset retainer
the reason i suggest the NPI crowers is because they dont need off set retainers if i am not mistaken!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old September 8th, 2007, 11:47 PM   #10
G.T. Rags's Avatar
Millenium Falcon
those weren't NPI?
Old September 8th, 2007, 11:48 PM   #11
The 270's are known to make good power however take what you read with a grain of salt. Most of the articles are paid for by the producers of the product, do you honestly believe they would say their parts lack power ?
Honestly it takes a healthy valvetrain to support the amount of lift you would want to throw at a Npi head. I machine the heads and guides to support the higher lift cams rather than doing the retainers. I also have to run a different valve seal to get reach the lift numbers I prefer. I have a set running a .638" lift cam on a 12:1 motor for a buddies car.
Old September 8th, 2007, 11:49 PM   #12
Proud American
VT doesnt make a NPI grind!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old September 8th, 2007, 11:52 PM   #13
G.T. Rags's Avatar
Millenium Falcon
i feel like a tard.......i mislinked u
sorry
Old September 8th, 2007, 11:54 PM   #14
Proud American
sorry
Yeah I think that that cam would be perfect for ya!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old September 8th, 2007, 11:58 PM   #15
G.T. Rags's Avatar
Millenium Falcon
so all i would need is some valve springs with this cam?
would i beable to drive the car to get it tuned after i have them installed?
i'm having trouble finding the lift for these cams...
Old September 9th, 2007, 12:13 AM   #16
Proud American
ya as far as when i researched them you will need the springs, but not off set retainers
also i plan to drive mine to the dyno, it should be safe as long as u dont get in the trottle and dont have PTV. And witht eh crower stage 2 NPI PTV will be non existant
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old September 9th, 2007, 12:24 AM   #17
G.T. Rags's Avatar
Millenium Falcon
whats PTV?
Old September 9th, 2007, 12:37 AM   #18
Proud American
Piston to valve issues
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old September 10th, 2007, 05:56 PM   #19
mexlatino's Avatar
1998 Mustang GT
mexlatino is on a distinguished road
whats dyno?
Old September 10th, 2007, 06:19 PM   #20
nes
nes is on a distinguished road
you dont have to dyno it, u can just datalog it with your tuner, but if you have no experience with any kind of tuning equipment, get it on the dyno. o0o and go meet the dyno guy ahead of time, get to know him and his shop a little bit better...
silver 98gt, blown- sold
laser red 98gt, stock- gave away
stormy blue 09 mazda3-traded
09 subaru wrx- soon to be 12 sec. daily driver
1988 gt- toy
Threads Similar to: Cams...
Best Cams hubba076 99-04 11 May 23rd, 2007 10:13 AM
CAMS leebunnyz 2005 - 2010 1 May 19th, 2007 05:14 PM
cams for a v6? Torry Jobe V6 Mustangs 22 March 15th, 2007 04:42 AM
PI cams 97_stang_gt 96-98 4 February 23rd, 2007 09:54 PM
cams landbstangcrzy 96-98 1 December 4th, 2006 08:15 PM
