Smelly Fists, Socking Cocks
Millenium Falcon
wierd grinding noise
so when i'm in 3rd and 4th gear just about to cross 3 grand thres this wierd noise. My Gf says she can feel a vibration in her butt when the noise occurs. It's a lil bit of grinding and clanking....thats the best way i can describe it.
i recently had a new clutch installed, flywheel resurfaced, and 4.10's installed. |
Millenium Falcon
s othe noise is coming from my rear end. Shop is closed on Monday, so i'm gonna have to wait to call them up on tuesday. No car for 2 days pretty much.
Proud American
well still drive it if need be. And the shop is going to have to fix what they mesed up on. And if you have to drive it and make it worse so be it, its there fault that they werent put in correctly. If the gear set is ruined make them buy you a set.
Hope they didnt button up your rear differential without using any fric. modifier with non-synthetic gear oil. I am guessin you had them use synthetic right?
Millenium Falcon
they only use royal purple in there rears........i went to a mustang only shop
that sucks dude....i hope its an easy fix
Millenium Falcon
ujstlost thinks it may be something as simple as the drive shaft bolts..........
hmm....did u check underneath?
Millenium Falcon
i'm gonna wait to have the shop look at it. I don't want them to tell me i tampered with something.
good idea....tellum to do it right next time
Sucks. If anyone deserves to have his rearend checked out by a competent mechanic ,its Ragtop.
Like I said,gears are a tight fit. You should be there when they take the diff cover off to see if anything comes out. And check the gears GOOD.
Fryrice has left the building. |
Millenium Falcon
what could possibly come out?
Shavings maybe. Im just sayin,dont let them tell you its ok without seein some proff.
Millenium Falcon
so i took the car into the shop today and they diagnosed the problem and fixed it for free. Nothing they did either.
i used to run 87, there's a convienant gas station right next door. I put 93 in it after i left the shop and within 4 miles the noise had stopped. Needless to say no more regular and no more gas station enxt door for me. I scheduled an appt to have them swap out my Cats for a Mac o/r pipe on friday. The only reason I'm letting him do it is because he said he would take care of me when inspection time came around. Me and my buddy r scheduled to do the PI intake swap this sunday. Ragtops got the itch baby......who wants to help me scratch it |
#15 | |
Proud American
Millenium Falcon
how hard is it to swap mid pipes?
do o/r pipes come with all the filangees and dodads i need to bolt them onto my stock header and stock cat back? on another note........NorthPort Ford just called.......my gaskets and stuff came in.......Wahoo! |
If you have any questions or need help with your intake swap, feel free to get in touch with me. I just did mine a few weeks ago. It's not REALLY hard, but you gotta have patience. The worst part was the 2 small bolts holding the coolant tube on the back of the motor. Talk about a bitch to get to...
Who cares what your import looks like... They'll all be laughing at you at the finish line. |
#18 | |
Millenium Falcon
#19 | |
RagTop,glad you got that squared away. But how is it you describe a grinding noise in the readend,and it turns out your using the wrong gas ? lol
Millenium Falcon
it was a grinding clanking noise........turns out it's a ping
Threads Similar to: wierd grinding noise
| wierd from noise | noppe180 | 96-98 | 5 | October 28th, 2007 02:26 AM |
| Wierd Noise..please help | tmab11 | V6 Mustangs | 1 | October 14th, 2007 06:48 PM |
| Wierd noise...help plz if you can | Danny01gt | 99-04 | 15 | January 13th, 2007 12:19 AM |
| wierd noise suggestions? | 02NEBstang | 99-04 | 2 | December 22nd, 2006 08:29 PM |
| Engine grinding noise help? | 320hpPony? | 5.0 Mustangs | 2 | May 21st, 2006 09:17 PM |
