zippeewannabee
Independently wiring foglights
hey guys i was just wondering.. how do you make it so your foglights come on without the headlights on? i read the article on AM and went out and did it and it didnt work
.. any ideas fellas?
ttt
-BBK CAI, BASSANI CB + X, SCT 93 tune, 4.10s, Cobra brakes, Cobra R wrapped in nitto 555 tire. -College Football and studies take up the bulk of my time. |
Proud American
u wired it wrong
The Hammer
Millenium Falcon
my fogs are messed up.......they only come on until the headlights r on, as apposed to when u turn the running lights on
zippeewannabee
well matt can you help me out here lol or can anyone help me out... i connected the black and red wire from the fog switch the the outgoing purple and orange wire from the convert. adapter..
![]() Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount |
MM's Coffee Addict
I did the AM directions as well, however they worked out perfectly for me. I love the look of the fogs on with only the driving lights... cool effect.
PM sent...
![]() Vortech V2, intercooled @ 10psi. Maximum Motorsports supsension goodie bag car less roll cage. Built '04 IRS. Hodge-podge of Roush/Stalker panels. |
#7 | |
My 2000 Cougar however would let you run fogs w/ running lights only stock. |
#8 | ||
The Hammer
Millenium Falcon
1997 Mustang GT
First off two words............Volt Meter lol
My foglights will not work until i have lights on also..........this is normal. As for solving your problem get a volt meter and measure the voltage at the convertable wires. Should be 12v +- as long as the key is on. Oh yeah.........and once you do this dont forget to turn your foglights off along with your headlights lol
1997 GT Cobra R Hood, Cobra Front bumper, MSD plug wires, Tailights, Projector headlights, 18x9 chrome bullet wheels in front and 18x10s in back, Tunable Induction Cold air intake, flowmaster mufflers. 4.10 Gears. |
Ok, if you disconnected the purple and orange wire, that's why it isn't working. You have to swap the red and black wire with the blue and red this should get it working
Who cares what your import looks like... They'll all be laughing at you at the finish line. |
zippeewannabee
oook thanks alot jbm and that wire should also be on the vert. adapter?
Yeah if you are looking at the red/black wire, its right below it. All you have to do is pull the red/black wire and switch it with the blue/red wire right beneath it. They should both be the 2nd wires from the right side on the plug. If you are holding the plug in your hand, red/black should be on top and blue/red should be on bottom. Just pull both out and flip them. This will get your fog lights working with your running lights and give you the look you want.
No problem on the help man. I just happened to read over it and see where you had pulled the purple/orange wire. Maybe no one else saw that part. Enjoy the new look. I know I have.
zippeewannabee
hold on a second lol ... so you cut the red and black wire and the blue and red... then you connect the blue and red from the plug to the red and black wire going away from the plug?
zippeewannabee
o sorry i didnt even see that but i really wanted them to work without any of the lights on thats where i got the purple and orange..
Oh my bad... Maybe I wasn't reading close enough. Those instructions from AM are kinda tough to follow. I'm not sure about how to run them without running them through either your running lights or headlights.
Sorry I couldn't help man.
IBEATU
06 GT, 98 GT, & 93 Notch
Yes, I know its a zombie thread.....but wanted to keep the info together. Any one have a link to wiring the fogs to come on by themselves and to run with the brights on?
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
Bringing Yellow Back
mine are on a switch
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
#18 | |
02 Mustang GT
^ if you follow this setup, your fogs will run so long as your key is in the on position (forward - to where your fuel pump primes)
IBEATU
so with that it will work whenever the factory foglight switch is on, correct? no matter whether your headlights are on or not, or even if they're on bright?
02 Mustang GT
the fogs will work as long as you have your key in the ignition and forward at least to the first click (run) they will not stay on if your keys are out of the ignition, or if your key is turned backwards to the accessory position. it doesnt matter if your headlights are on, it doesnt matter if your brights are on, the only thing that matters is the key. i followed that method because i didnt want to accidentally leave my fogs on and drain my battery.
Threads Similar to: Independently wiring foglights
| removing foglights | JaxnsGT | 99-04 | 9 | October 26th, 2007 04:38 PM |
| Switching to GT foglights | trueballerisme | Audio/Video | 7 | October 2nd, 2007 11:58 AM |
| foglights | Nick_Rapitis | V6 Mustangs | 7 | August 15th, 2007 12:28 AM |
| blue foglights??? | tsp_2177 | Visual | 14 | April 20th, 2007 01:10 PM |
| foxbody gt foglights | 1990CA50 | 5.0 Mustangs | 2 | December 12th, 2006 06:58 PM |
