Discussing problem help!! in the 96-98 Forum. for some reason tonight my car decided to die whenever i put it in neutral ...
Old September 9th, 2007, 10:27 PM   #1
The Great Unknown
Dennis-96GT's Avatar
11h47m32s
problem help!!
for some reason tonight my car decided to die whenever i put it in neutral and only in neutral i can put it in park its fine drive fine just when i put it in neutral while stoped it dies and wont start in park wont even crank it will only restart in neutral then i have to throw it in drive quickly to keep it from dying again now i did put a can of seafoam in the gas no clue if that makes a difference
MEMBERS AGAINST STREET RACING
Old September 9th, 2007, 11:04 PM   #2
bossman2kgt's Avatar
Did you run seafoam bfore or after you started having this prob. Just thought u mighta forgot to plug your vacuum lines back in.
Old September 9th, 2007, 11:15 PM   #3
The Great Unknown
11h47m32s
nah i ran the seafoam only in the gas this time on a full tank i did the 3 part a long while back that was fun
Old September 9th, 2007, 11:20 PM   #4
check your fuel pressure.
Threads Similar to: problem help!!
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 01:03 PM
Has your car ever had a problem? JASonic The Clubhouse 17 September 19th, 2007 06:19 PM
big problem need help 96gtponyred 96-98 12 August 22nd, 2007 02:36 AM
RIM Problem and Help trueballerisme 2005+ 70 August 21st, 2007 09:55 PM
TPS Problem? 88Horseman 5.0 Mustangs 11 November 14th, 2006 12:46 AM
