Discussing Pi Cams vs. NPI cams in the 96-98 Forum. Several of the cars on the MM&FF site run Ported and Polished PI ...
Old September 12th, 2007, 07:15 PM   #1
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
Several of the cars on the MM&FF site run Ported and Polished PI heads but run after market NPI cams. Does anyone know why?
Old September 12th, 2007, 07:19 PM   #2
All Throttle with a Bottle
MustangMatt96GT's Avatar
Because its MM&FF
1996 Mustang GT with a 351 swap with Stalled C4
1997 F250 Powerstroke
1999 28' Classic Dominator
Special Thanks to: Andrews Racing Transmissions
& Thanks for the help: PoorManMotorSports
"Just Cause its Smoking, don't mean its broken"
Old September 12th, 2007, 07:34 PM   #3
1997 Mustang GT
Faster than an s4
But is there any real reason. I heard it has to do with longer duration. I guess thats possible but I would think that an after market cam would have the longest duration they could get anyways along with the larger lobe size. But I don't know.
Old September 12th, 2007, 08:20 PM   #4
<<<<<From a headporters view ; the air speed stalls on the P.I head around .500" lift (.480" to be exact). Taking the lift beyond that in some cases will cause a lose of power depending on the combo. Every combo requires a different cam to see peak potenetial....
Old September 13th, 2007, 12:11 AM   #5
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83
ptv issues also. the npi cars have less dish in the pistons giving higher compression and clearance issues.
right now, she is a jackstand warrior
if the car was a horse, i would shoot it!!!
Old September 13th, 2007, 01:53 PM   #6
1997 Mustang GT
Faster than an s4
I know that you can do a straight swap from NPI heads to PI heads. with the intake and cams and everything. But the question I have is, will I get more power with the PI cam than the NPI one. I think so, but what about with a stage 2 head?
Old September 13th, 2007, 05:02 PM   #7
The dish is not an issue, the valves hit the outer 3rd of the piston when PTV occures. Lift will not determine PTV as the valves are open fully near BDC, overlap is more of a concern.
Note: piston to valve interference usually occurs during the first .200" of lift.
A ported head will lead to better performance when done correctly and with the proper supporting mods.
Old September 13th, 2007, 05:12 PM   #8
1998 Mustang GT
Need to hit the track
and what kind of supporting mods are those?
also, what kind of pistons would i need if i wanted to drop the compression of my engine after my PI swap
aannnnd, would it be better to drop the compression after the PI swap or just leave it how it is?
Old September 13th, 2007, 06:19 PM   #9
1997 Mustang GT
Faster than an s4
SO i guess, that you can use either in a NPI engine is what your saying. Just to make sure the cam you get will not have any PTV issues. I just want to know if I'll make more power with a NPI stage 2 or a PI Stage 2. Since they are PI heads and stock PI cams do more than PI cams, the Stage 2 PI cams would be best. Right?
Old September 13th, 2007, 06:34 PM   #10
I believe if u try and run a PI stage 2 cam in NPI heads u will have problems but Boomer will know for sure
Threads Similar to: Pi Cams vs. NPI cams
Best Cams hubba076 99-04 11 May 23rd, 2007 10:13 AM
CAMS leebunnyz 2005+ 1 May 19th, 2007 05:14 PM
cams for a v6? Torry Jobe V6 Mustangs 22 March 15th, 2007 04:42 AM
PI cams 97_stang_gt 96-98 4 February 23rd, 2007 09:54 PM
cams landbstangcrzy 96-98 1 December 4th, 2006 08:15 PM
