Help with ABS system
Old September 17th, 2007, 09:25 PM   #1
blownsnake96's Avatar
1996 Mustang Cobra
blownsnake96 is on a distinguished road
The ABS light on my 96 Cobra came on the other day and now it keeps blowing the fuse for the brake lights. I can replace the fuse and all is good until I hit the brake pedal, then pop! I just had my motor built, and the guy told me to bring it back and he'd check it out, but I wanted to try to fix it myself. I don't wanna spend the $$$ to take it to a dealer. Anyone have any ideas? Thanks!
Old September 17th, 2007, 09:27 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
welcome to the forums.
check your abs lines on your brakes.
you might have knocked a sensor loose.
Old September 17th, 2007, 09:35 PM   #3
ujslost's Avatar
your brake light switch under the pedal is possibly shorting to ground
Old September 17th, 2007, 09:37 PM   #4
ujslost's Avatar
also check your owners manual to see what all is on that circuit thats blowing the fuse
Old September 18th, 2007, 06:14 AM   #5
1996 Mustang Cobra
ABS
I've already replaced the brake light switch. It won't blow the fuse until the car is rolling. In other words, I can put in a new fuse and everything will work fine- even the brake lights- but the first time I hit the brakes after the car starts moving it will blow the fuse. I've looked under the car and all the ABS sensors seem to be ok, could a bad sensor cause it to do this? Maybe the pump's not working? I don't have a clue about ABS stuff. Thanks again for any help!
Old September 18th, 2007, 09:16 AM   #6
ujslost's Avatar
What else is on that circuit? Look in your owners manual, find that fuse, and what else is using that fuse?
Old September 19th, 2007, 12:34 AM   #7
1996 Mustang Cobra
I don't have an owners manual(bought it used), but when the fuse blows, I lose brake lights, turn signals, and hazard lights. I'm gonna take it back to the shop that built it for some tuning adjustments, they said they'd check it out for me. I just wish I could figure it out. Gonna check the sensors this weekend by unplugging them one at a time to see if that changes anythin Somebody told me the rears are the ones that detect motion, and one on the diff. I guess we'll see.. I'll post if it fixes it. Thanks again for your help.
Old October 28th, 2007, 10:04 AM   #8
1996 Mustang Cobra
I got the problem fixed! There is a wiring harness that goes across the top of the radiator and down to the ABS module. Some of the wires had bad places in them and were shorting out against the radiator.
96 Cobra
Procharger D1SC at 15 psi
BBK Longtubes, Magnaflow exhaust
Tremec trans, 4:10's, the works...
Built and tuned by Atlanta Chassis Dyno
530 hp / 420 tq at the tires
Old October 28th, 2007, 10:09 AM   #9
HMUSN's Avatar
iTrader: 9 reviews
glad you got her all fixed up.
Old October 28th, 2007, 11:00 AM   #10
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
:homo
ΜΟΛΩΝ ΛΑΒΕ
Old October 28th, 2007, 12:52 PM   #11
Proud American
MustangMatt96GT's Avatar
glad u got it fixed
Now stay around for a while.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Threads Similar to: Help with ABS system
Traction Control System (TCS) and Anti-Lock Braking System WAR-PARTY 99-04 14 May 1st, 2011 03:17 PM
Traction Control System (TCS) and Anti-Lock Braking System WAR-PARTY 99-04 11 June 18th, 2007 08:56 PM
C & L maf system.... minigunner7point62 V6 Mustangs 2 June 17th, 2007 01:47 AM
Cold Air Intake System/Shaker System Bish Audio/Video 11 June 16th, 2007 12:04 AM
New System 94mustanggt Audio/Video 6 August 25th, 2006 02:48 PM
