What can I do to fixs this DTC p1443
It said it was the Evaporative Emission is flowing low or not flowing. how would I go about fixing this.
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
04 GT SOLD 96 GT SOLD 03 COBRA STOLEN 89 LX SOLD 88 GT SLOW 06 F150 FX4 |
first check youre gas cap. On most fords they have a VERy simple EVAP system. I have seen problems with the purge valve before. But without doing a check on the system myself i cant guide you in a certain direction.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
It says that there is low to no flow. Could that be a broken line.
These DTC ( diagnostic trouble codes ) are basic and can have multiple problems for the same code. You really need a place that can diag. evap concerns to check it out. Evap is touchy ( even more so on jap cars ). But fords like i said before have pretty basic evap systems. So first i would check the gas cap. If its tight, did you fill up with the car running ? If all this is ok i would go ahead and replace the purge valve. Could be sticking and not letting anything by, or its stuck totally. Could very well have a pinched line. If it had a broken line like you said, you would be getting another code suggesting you have a gross leak.
HX52 DTC P1443: EVAPORATIVE EMISSION SYSTEM VISUAL INSPECTION
Visually inspect for: EVAP system lines/hoses (check for proper connections, damage or blockage) Loose fuel vapor hose/tube connections to the EVAP system components. The vacuum line from the input vacuum port to the intake manifold on the EVAP canister purge valve (the control vacuum solenoid part of the valve) is removed. Blocked vacuum hose between the EVAP canister purge valve solenoid and the engine intake manifold. Damaged fuel tank or fuel filler pipe. Thats fords description. I would replace the purge valve. Its under the right front wheel well in a 2004 Gt. Removed the wheel well cover and then its in the upper right hand corner.
This is for the 96...
Threads Similar to: What can I do to fixs this DTC p1443
| Code P1443 After using seafoam!??! | 97redgt | Modular Mustangs | 3 | September 28th, 2007 02:22 PM |
| p1443 where is the evap emissions valve? | born2mustang | V6 Mustangs | 13 | August 12th, 2007 05:42 PM |
| P1443 | 97_4.6L_Stang | 96-98 | 13 | August 2nd, 2007 08:32 PM |
| rough idling, code p1443 | cyrax01 | 96-98 | 6 | August 22nd, 2006 10:44 PM |
| Code P1443 ? Please help | 97Cobra | 96-98 | 2 | April 16th, 2006 05:47 PM |
