drivers window won't stop on auto
Old September 23rd, 2007, 02:46 PM   #1
acobraman's Avatar
96 Cobra Vert. , 97 Cobra
12.55@111.33
acobraman is on a distinguished road
my drivers side window goes down on auto and it won't stop. sound like it's trying to tear the shit out of something. any ideas?
Old September 23rd, 2007, 08:39 PM   #2
bossman2kgt's Avatar
bossman2kgt is on a distinguished road
First off welcome to MM!
I have never heard of this problem. Is this only happening on the drivers side? I would pull the door panel off and take a look at it. Look carefully at the wiring and see if there is anything funny.
Old September 24th, 2007, 05:21 AM   #3
acobraman's Avatar
12.55@111.33
I had the panel off and I couldn't see any problem. Of course, it's a pretty tight space in there, so there's not that much to look at. It's only on the drivers side.You know how you click it once and it'll go down by itself? Well, it just won't stop.
Old September 24th, 2007, 10:20 AM   #4
I would call a ford tech maybe at your local deapership. It sounds like some type of power surge but I am not an expert on that stuff. There may also be some type of module or sensor that tells the motor to stop when the window triggers it. Ask the tech that. Let us know when you figure it out. Sorry cant be more help.
Old September 25th, 2007, 07:09 PM   #5
acobraman's Avatar
12.55@111.33
I called the ford house today and they said it could be the regulator or the window motor. someone else has told me it is the motor, so I guess I'll try that first, just not real soon.Will let you know when I find out for sure.
Old September 25th, 2007, 07:35 PM   #6
Maybe its a faulty regulator. I doubt its the motor.
Old September 26th, 2007, 06:00 PM   #7
acobraman's Avatar
12.55@111.33
ok, thanks, where or which one would that be?
Old September 26th, 2007, 07:01 PM   #8
Can you take a pic of the drivers side door interior and zoom in on the motor and the regulator. I am now pretty sure its your motor. I was thinkin something else when I said regulator. Just take a pic. That should help a little.
Old September 26th, 2007, 11:22 PM   #9
ujslost's Avatar
its not your regulator, its probably either the switch or the motor.
does it do this when you use either the drivers side switch or the pass side switch? if it does it on both switches i say motor, but ive never seen a motor do it, so im leaning towards switch
Old September 27th, 2007, 05:30 AM   #10
acobraman's Avatar
12.55@111.33
it's just the drivers side and I don't think you can even see it. (the motor)I'll look again this weekend.
Old September 27th, 2007, 08:38 AM   #11
ujslost's Avatar
my bad, i dont know where i got the idea you meant pass side. i guess cause i just had read a thread where someone wanted to put auto windows on his pass side.
Threads Similar to: drivers window won't stop on auto
Drivers window motor ByPopularDemand General Tech 13 September 15th, 2007 01:49 AM
transmission slipping/hunting? Drivers side power window? jasburrito 94-95 4 August 27th, 2007 02:39 PM
drivers side window regulator removal? jrfan4life 99-04 3 July 29th, 2007 12:50 PM
Drivers side window won't go down. 8A_Honda V6 Mustangs 18 July 19th, 2007 12:41 AM
drivers side window firefly1241 5.0 Mustangs 12 December 5th, 2006 01:33 PM
