4.6 spitting problem
Old October 8th, 2007, 11:36 PM   #1
suds488's Avatar
Est 13.9-14.5
suds488 is on a distinguished road
Im having a problem with my mustang spitting. It doesn't sound like it is missing and I have no power loss in the higher RPMs. Only when it is sitting at idle and very low throttle does it do this. No trouble code is being generated and none of the plugs are fouled. I have no I idea what it is. I have MSD coils and wires that were just put on less than 2000 miles ago. Could one of the wires be bad?
Old October 9th, 2007, 03:01 AM   #2
memphismustang87 is on a distinguished road
Do u feel it when i spits or is it just noise? Mine acts up a little also sometimes and I have been tryin to narrow it down.
98GT 5spd,KYB shocks & springs,K&N,new plugs & FR Wires,BBK O/R H-Pipe,Flows,Pro50 short-throw,Bullit DD Rims,2.5% tint,4.10 gears,Proj. Headlights,Mach I Shaker
Old October 9th, 2007, 02:28 PM   #3
suds488's Avatar
Est 13.9-14.5
It spits and it seems like the engine shutters and when it is in gear in the lower RPMs (like 1 1/4 to 1 1/2 grand) it bucks a little until you give it some more gas. Ive never had any problems in the upper RPM range.
96 GT AKA-Bethany 230rwhp 305rwt before head gasket leaked oil into 2 cylinders.
Rebuild in process....PI Heads P and P'd, Manley valves, Ported PI Intake, 75mm Plenum and TB, 24 Lb injectors, SCT dyno tuned, O/R xpipe, Merit Mufflers.
Old October 9th, 2007, 04:56 PM   #4
Yeah. It sounds alot like what I'm feelin and hearing. I don't know if it is engine or transmission related yet. I'm gunna have a mechanic help me find the problem w/in the next month probly. It seems to mainly happen when it is warmed up for a while or driven hard. And like urs, only when not under a load, or only when the rpms are low. I have alot of engine shaking also, especially when idleing.
Old October 9th, 2007, 08:42 PM   #5
suds488's Avatar
Est 13.9-14.5
I just don't know what else it could be. I would think if it was an injector it would throw a trouble code. I guess that always wouldn't be the case. Let me know what you figure out.
Old October 10th, 2007, 01:39 AM   #6
Yeah, I will. U do the same.
Threads Similar to: 4.6 spitting problem
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 01:03 PM
t-5 problem notsoslow50 5.0 Mustangs 7 August 17th, 2007 08:16 PM
BBK Problem UTGT Modular Mustangs 4 July 26th, 2007 01:41 AM
Spitting Cobra 07stanggt Modular Mustangs 28 June 4th, 2007 10:29 PM
86 Jeep spitting antifreeze 97Cobra All Other Vehicles 3 November 28th, 2006 11:49 AM
