nitrous oxide
Old October 13th, 2007, 03:02 PM   #1
1996 mustang gt
gtdan is on a distinguished road
Send a message via Yahoo to gtdan
nitrous oxide
does anyone have pics on wiring a nitrous system to a switch or button i got it @ open throtle and want to go wit the button .is a dry shot system
Old October 13th, 2007, 05:28 PM   #2
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
I hope this helps you some...Sorry if it don't
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old October 13th, 2007, 05:30 PM   #3
2003 SVT Cobra
The above is for a dry kit with a fuel pressure safety switch, arming switch, wide open throttle switch, and window switch all rolled into one
The only part you can't tell what it says in the lower right cornor is the tach output wire for the window switch activation.
Again, I hope it helps you some. If not let me know and I'll see if I can dig something up.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Old October 14th, 2007, 12:09 AM   #4
1996 mustang gt
dang that looks confusing whats a window switch? do i need a arming switch? and is there any corners i could cut or is this like a safety thing/
sold the stang
Old October 14th, 2007, 12:34 AM   #5
2003 SVT Cobra
A window switch is a device that activates the nitrous at certain RPM intervals. Unless you have a setup that is made specifically for running nitrous than it's a general rule of thumb that you don't want to spray before 3000 RPM and you don't want to spray when you hit the rev limiter because that will cut the fuel to your motor, and no fuel plus much nitrous equals BOOM! Say your rev limiter is set at 6000 RPM. Then what you do is set the window switch to activate between 3000 RPM and shut off around 5700 RPM (before you hit the limiter)
A lot of people will tell you that they are not necessary. You can just tune your rev limiter out and activate the nitrous manually with the arming switch around 3000 RPM.
The other thing is the FPSS (Fuel Pressure Safety Switch) what that does is shut the nitrous off if there is not enough fuel pressure. 9 out of 10 times if something goes wrong with a nitrous run it's because there was not suffeciant fuel to mix with the nitrous.
Again, this is something that is not absolutely necessary.
I have another diagram somewhere of just a simple dry setup that is basically just selanoids, arming switch, and WOT switch. I'll see if I can find it, but if not I have one at work I can scan and post for you when I go back on Tuesday.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Old October 14th, 2007, 12:58 AM   #6
1996 mustang gt
thanxs man really D@ts really helpfull man
sold the stang
Threads Similar to: nitrous oxide
Intelligent nitrous oxide.... homebrewed General Tech 21 June 1st, 2007 05:57 PM
Nitrous Oxide help TDog 2005 - 2010 11 April 12th, 2007 08:53 PM
Nitrous oxide questions Barrier Modular Mustangs 4 January 29th, 2007 12:24 PM
Nitrous tlgrant 99-04 22 December 20th, 2006 02:31 AM
