Intake Cracked!!!!!!!!!!!!!
DAMN INTAKE THING!!!!!!!!!!!!!!! OK after I have let some frustation out, why are these intakes plastic.
What the hell Ford playing at, lol. So my question now is can I get a PI Intake for a non-pi engine or whatever you would call the other parts. I don't have the money for this intake anyways, let alone a PI Swap of any sort so please don't get me into that stuff, lol. ALso how much do these things cost, about how much. Thanx for anything. |
You can get the PI intake for your car but if you do make sure u get the one with the aluminum crossover. Or you can get the NPI intake with an aluminum crossover.
would the PI Intake be better for the car?
It will help but i cant say how much because i havent done it to my car. You would have to ask some people on here who know a little more about it.
10 15 hp get the intake anyway i sell them over the counter for 200
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
if you do a PI intake swap, you will have a noticable difference in power. it adds like 10-15HP. After i did mine i instantly felt it when i got on it. Its a lil bit of work, but worth it. you can have it done over the weekend. Read this tread and you will have a lot better idea of what it takes http://www.moddedmustangs.com/forums...ap-vt1878.html
1996 Mustang GT -MAC CAI -Polished 75mm TB and upper plentum -PI Intake Manifold -BBK underdrive pulleys -MAC Long Tube headers -Shorty H-pipe -Flowmaster Exhaust -18x9 275x35xR18 all around |
Smelly Fists, Socking Cocks
Millenium Falcon
Most of the Boost in power u get from the PI swap is from the Intake itself. But when u combine both PI cams and Intake, you'll really open the car up.
45rwhp for under 500 bux........ u just need a good game plan after that if u want to make more power. Coughs*** blower***coughs |
Well now that your intake has finally cracked, I would say its been on borrowed time for about 5 years now anyhow so ya really cant bitch.
The plastic intake isnt a bad idea really, the plastic crossover was a bad design and thats why ford recalled it. Apparently the previous owner that had it during the recall never had it done. Get the PI intake, and be done.
1986 Mustang GT t-top time piece! |
Millenium Falcon
even the updated NPI intakes crack.........
just in the back |
+1 on my intake install +its pretty simple
im not much of a fan of the pi intake swap on a npi headed cars, yes for some it works great but everyone runs into problems and alot of people have leaks, do the whole swap if your going to do it, if not its not worth the trouble and aggravation of 12-15 rwhp
-BBK CAI, BASSANI CB + X, SCT 93 tune, 4.10s, Cobra brakes, Cobra R wrapped in nitto 555 tire. -College Football and studies take up the bulk of my time. |
Millenium Falcon
u gain more then 12-15 rwhp........more like 20-25...
and i also know plenty of people that have the swap done for over a year and have had no problems....... |
20-25, thats a load of bull man, an intake manifold is not gaining you 30 hp sorry if that was the case my 98 gt would be 5 hp less than an 99-04 sorry doesent add up more like 15 from the intake 15 cams 5 from the heads, is the difference from npi vs pi
not to knock(mm) this forum or anything but there is alot of information that is misleading people http://www.sn95forums.com/forum/index.php?topic=16908.0
#16 | |
Millenium Falcon
can u tell me why ur car is rated at 225 hp amd mine is rated at 215? |
dude i got my car dyno'd after having the PI intake put on
i gained apprx. 22hp after i adjusted the timing and a/f ratios and such get ur facts straight dude..
[SIGPIC][/SIGPIC] [SIZE="5"][FONT="Arial Black"]OBEY THE FACE![/FONT][/SIZE] Edited By Moderator. Next time will be a ban. |
Would this work..?
http://www.livernoismotorsports.com/...?p=457&large=1 '96-98 4.6L PI Intake Adapter Kit Finally, a kit that allows the P.I. manifold to bolt on to the 96-98 4.6L Ford 2-Valve modular engine. The new kit uses specialized adapter plates, a modified intake manifold (un-modified manifold will not clear stock hood), and gaskets to make it a direct bolt on with limited alterations. The kit is packaged so well that it will allow the use of a stock hood and strut tower brace. During testing we have seen as much as 35 rear wheel horsepower on a stock application. Tuning may be required due to the increase of airflow from the Non-PI Intake manifold. The kit consists of (2) Adapter Plates, a modified PI Intake Manifold, PI Intake Gaskets, all Hardware (Bolts, New Coolant Tube, Coolant Tube Fitting, Heater Hose and Alternator Spacers), and detailed instructions. |
you adjusted your timing and af ratios that doesent count toward a pi swap you get your facts straight moron
baby 96 i would definatly buy that kit, its proven safe and delivers the same results, why ghetto rig an intake that may cause problems, when you can buy something thats proven
Threads Similar to: Intake Cracked!!!!!!!!!!!!!
| intake manifold cracked... got a new one but havin problems | 96gtstang&V6 | 96-98 | 11 | November 7th, 2007 11:07 AM |
| cracked intake | mr. mopar | 96-98 | 15 | October 3rd, 2007 07:23 PM |
| Cracked oil pan please help | 99v6stang | V6 Mustangs | 12 | April 7th, 2007 01:08 PM |
| Cracked Intake Manifold | cyrax01 | 96-98 | 12 | November 3rd, 2006 09:35 PM |
| cracked intake | bdp55 | 99-04 | 2 | October 21st, 2006 03:11 AM |
