Clutch pedal hard, now its just gettin annoying
Old August 12th, 2006, 08:08 PM   #1
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
Since i converted from an auto to a 5 speed the clutch has been really tough. it doesnt bother me to much now but if i get in my friends 5.0L truck and drive it, the clutch is like twice as easy to depress. i dont know what may be causing this but id like to find out. When we put the thing together i had a mechanic with me and watched over every part and used the allignment tools. yahta yahta so i dont know what gives.
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Old August 12th, 2006, 09:04 PM   #2
mdvaldosta's Avatar
11.47@120.58
What kind of clutch did you install? Many aftermarket performance clutches have a stiff feel. Also, if it was an aftermarket clutch, did you replace the quadrant as well?
Old August 12th, 2006, 10:35 PM   #3
stang fanatic's Avatar
stang fanatic is on a distinguished road
Question actually...whered you get the parts? all new products or off of a donor car? If you used, used parts, you may be experiencing a wear issue.
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old August 13th, 2006, 11:33 PM   #4
All Clutch parts, alignment tools, throwout bearing, pressure plate and clutch disc were new stock items from advance auto. Not an aftermarket, just stock clutch.
Old August 13th, 2006, 11:36 PM   #5
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
you probably didn't run the cable in its correct location. the cable is probably binding up and it will break soon.
TT Build in progress.......
Old August 14th, 2006, 06:34 AM   #6
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
You will be in a bad part of town and you will have to float you gears all the way home.
Classic Mustangs are the best! Get one.
Old August 14th, 2006, 04:20 PM   #7
So you think the cables bad then? how exactly is it suposed to be ran. the way we ran it didnt seem to interfere with anything really but i'm not sure. could the cable of potentially been bad from the start? i imagine that doesnt happen all to often.
Old August 17th, 2006, 12:28 PM   #8
320hpPony?'s Avatar
320hpPony? is on a distinguished road
Send a message via MSN to 320hpPony?
More like it was routed so that when pressure is put on it it tends to "kink".It may look like it's in a gr8 place when it was put in but once u push the peddle it's another story.Get some one to push the peddle in a few times while u look at the cable and ssee if u can see where it is binding.Some times a simple big ol' ziptie will fix something like that if put in the right place.
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it!
Threads Similar to: Clutch pedal hard, now its just gettin annoying
Squeeky clutch pedal... 1FastFox 2005 - 2010 5 June 4th, 2007 07:38 PM
clutch pedal xxrals22xx V6 Mustangs 12 March 4th, 2007 01:07 AM
Clutch Pedal 06dkkiser V6 Mustangs 5 December 5th, 2006 07:50 PM
Gettin a New Clutch 4point6GT 96-98 6 June 26th, 2006 07:29 PM
Clutch Pedal 2002Beast 99-04 9 April 28th, 2006 12:28 PM
